WTB Oil Temperature Sender 74 2.0 in Consul oil temp gauge, Oil temperature sender Part # 039 919 268 |
wes |
May 14 2016, 12:38 PM
wes Group: Members Posts: 1,589 Joined: 8-December 07 From: Ukiah Ca Member No.: 8,436 Region Association: Northern California |
I need a Oil Temp Sender part # 039 919 268 for my 74 2.0 in the Consol type.
Its just the sender that I need! |
Yahmann |
May 14 2016, 06:34 PM
Newbie Group: Members Posts: 29 Joined: 18-April 15 From: Topanga Canyon Member No.: 18,648 Region Association: Southern California |
I have a sender that screws into the oil pressure sender on top of the engine. It has 2 leads, one for temp and one for pressure. In the package VDO. I bought this when installing a temp gauge and didn't want to spend the $$ to find and buy the unit that installs on the bottom of the engine. I never installed it. This sells for $70 online - which is what I paid, I'll sell for $55 including shipping.
Attached thumbnail(s) |
bdstone914 |
May 14 2016, 07:14 PM
bdstone914 Group: Members Posts: 4,533 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
That is an pressure sending unit not for temperature. See the lable? One post is for a pressure gauge and the other for a low oil light. Temperature should be measured in the sump.
bdstone914 |
May 15 2016, 06:28 AM
The current VDO sender is 323-055. Available for under $20 from many sources. Do a google search.
bdstone914 |
May 15 2016, 06:36 AM
That is an oil pressure sending unit for a 0-80 psi gauge not temperature gauge. See the lable? One post is for a pressure gauge and the other for a low oil light. Temperature should be measured in the sump. You also paid too much. They can readily be found for around $45 new. That wont work for the OP or you if you are trying to measure the oil temp. Bruce |
bdstone914 |
May 15 2016, 06:54 AM
wes |
May 15 2016, 09:23 AM
I've found that to be true but no aftermarket replacement available?
Lo-Fi Version | Time is now: 2nd June 2024 - 07:05 PM |
