Turbo Twist Wheels? |
gisound |
May 16 2016, 02:36 PM
Newbie Group: Members Posts: 13 Joined: 15-February 06 From: Prosperity, SC Member No.: 5,584 |
Got a line on a good set of 18" Turbo Twist Porsche wheels off of a boxter. They will be going on a my car once I install the FG flares. That is if they will fit. They are 18"x10 (65mm ET) rear and 18" X7.5 (50mm ET) front. Do you think they will work on the 914 with flares? Also anyone have pics of these on a 914?
Thanks again, Blair |
SirAndy |
May 16 2016, 02:42 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Got a line on a good set of 18" Turbo Twist Porsche wheels off of a boxter. They will be going on a my car once I install the FG flares. That is if they will fit. They are 18"x10 (65mm ET) rear and 18" X7.5 (50mm ET) front. Do you think they will work on the 914 with flares? Also anyone have pics of these on a 914? Thanks again, Blair Stock GT flares? If so, the 18x10 won't fit, even if they had perfect offset. The GT flares are made to fit 15x9 wheels. (IMG:style_emoticons/default/shades.gif) PS: However, if you get metal flares, you can widen them to fit your wheels and tires. |
Mike Bellis |
May 16 2016, 03:41 PM
AIR makes a wider rear flare in fiberglass... (IMG:style_emoticons/default/smile.gif)
Cracker |
May 16 2016, 03:53 PM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
JFYI - They weigh a ton...each.
T |
matthepcat |
May 16 2016, 04:31 PM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
I think the offset on those is way off. I had a set on one of my previous cars, and I had to run 100MM studs with the largest wheels spacers from Weltmeister.
Andyrew |
May 16 2016, 05:06 PM
Yes I run 18x10's in the back. Spacers galore though.. I have about 2.5" of spacers in the back, just make sure you run quality spacers.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i719.photobucket.com-626-1307840093.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/a1.sphotos.ak.fbcdn.net-172-1321246691.9.jpg) I run Boxster turbo twists in the front though, the rears that is (17x9) for more tire. Bunch more pics in my signature. |
Lo-Fi Version | Time is now: 10th June 2024 - 07:46 AM |
