question for body/paint guys |
jmitro |
May 19 2016, 09:43 AM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
my car is getting media blasted this week. I still have a lot of sheetmetal replacement/work to do but I want to primer the car before I continue. There's so much information out there on the interwebs it's confusing for a newbie. So.....
1. what type of coating? POR15 or just epoxy primer? 2. does the metal need a prep or wipe down before priming? with what? 3. after the primer is sprayed, do I just grind it off to do body work and then repsray? Can I apply body filler over the primer or does it go directly to bare metal? 4. Can I spray high-fill primer over the base epoxy primer? |
Andyrew |
May 19 2016, 09:54 AM
my car is getting media blasted this week. I still have a lot of sheetmetal replacement/work to do but I want to primer the car before I continue. There's so much information out there on the interwebs it's confusing for a newbie. So..... 1. what type of coating? POR15 or just epoxy primer? 2. does the metal need a prep or wipe down before priming? with what? 3. after the primer is sprayed, do I just grind it off to do body work and then repsray? Can I apply body filler over the primer or does it go directly to bare metal? 4. Can I spray high-fill primer over the base epoxy primer? 1. Epoxy Primer 2. Wax and grease remover 3. Body filler over metal is fine. Body filler over primer is fine. After your done with bodywork spray another layer of urethane primer "Primer sealer". You can thin this down to paint level. This will seal everything in and give you a rust barrier. Paint goes directly over it. 4. Yes. |
Amphicar770 |
May 19 2016, 10:02 AM
Senior Member Group: Members Posts: 1,195 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
What Andyrew said.
A good autobody supply / paint shop is your friend. Try to stay within the same family of products (i.e. PPG). |
jmitro |
May 19 2016, 11:25 AM
great, thanks guys (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 2nd June 2024 - 05:18 AM |
