78.4 mm stroke for 2270 cc, Is piston skirt protrusion an issue? |
DaveO90s4 |
May 25 2016, 08:52 PM
Member Group: Members Posts: 149 Joined: 26-April 16 From: Australia Member No.: 19,935 Region Association: None |
Dear brains trust,
I see that one if the problems with stroking LS engines is the fact that the piston skirt comes out of the liner more than for non stroked at the bottom of the stroke. This in turn leads to more piston wobble on the upstroke, increased piston skirt wear and increased oil consumption. Is this also an issue with the 78.4 stroke crank in a 2270 cc Type 4 engine? Is that a reason for staying with the 2.0 standard 71 mm stroke and going for a 2056cc engine instead? Thanks Dave |
Jake Raby |
May 25 2016, 09:32 PM
Dear brains trust, I see that one if the problems with stroking LS engines is the fact that the piston skirt comes out of the liner more than for non stroked at the bottom of the stroke. This in turn leads to more piston wobble on the upstroke, increased piston skirt wear and increased oil consumption. Is this also an issue with the 78.4 stroke crank in a 2270 cc Type 4 engine? Is that a reason for staying with the 2.0 standard 71 mm stroke and going for a 2056cc engine instead? Thanks Dave It can be an issue, if you use a short (stock length) rod and some Pistons. If you use a 5.400" rod and a piston with a 1.112" pin height, or more, you'll be fine. |
DaveO90s4 |
May 26 2016, 05:14 AM
Hi Jake, thanks for your expertise. I'll contact the type 4 store and verify that their products meet that spec. Which for obvious reasons I'm pretty confident they will.
Now to find a complete engine to to the rebuild on (leaving my matching numbers engine un-tampered). Thanks once again Dave |
Jake Raby |
May 26 2016, 10:10 AM
Yep, they sell what you need.
Lo-Fi Version | Time is now: 2nd June 2024 - 08:39 AM |
