Drivetrain drop in folding car... |
Tbone425 |
May 31 2016, 07:54 PM
Newbie Group: Members Posts: 43 Joined: 15-August 15 From: AZ/WA Member No.: 19,065 Region Association: Southwest Region |
Looking for some advise on dropping eng/trans in a car that is soft in the middle. For obvious reasons I don't like the thought of having any part of me under it. Here is what I was thinking, I might lift the back, Jack stand and wood block every hard point. This would give me some safety...at least to some degree while I made all of the enderside disconnects.
Then I thought I would remove the rear wheels, slide a pallet under and then drop the car down over the pallet and remove the entire package including suspension and trailing arms. I figured that I could also cut it out from the top if needed, as the body is gone. Any thoughts or suggestions? Thanks folks! |
r_towle |
May 31 2016, 08:22 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
If the body is junk, cut both rear tranny bolts from behind with car on ground.
Cut front engine mounts and inner suspension mounts from above Cut out suspension mount from beside the car Remove upper shock bolt Lift car off motor Cut shifter rod of required Lift car, drag motor out from behind Been there done that |
Tbone425 |
May 31 2016, 10:45 PM
If the body is junk, cut both rear tranny bolts from behind with car on ground. Cut front engine mounts and inner suspension mounts from above Cut out suspension mount from beside the car Remove upper shock bolt Lift car off motor Cut shifter rod of required Lift car, drag motor out from behind Been there done that Sounds like that might be the best route. Don't trust being in this rig...let alone under it. |
injunmort |
Jun 1 2016, 07:24 AM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
having just done this. the car i cut up, folded over as soon as i lifted it. i set it back down, removed the rear glass. i jacked up the back of the car under the bump to get more or less level. i used two tie down straps from the targa bar to rear bumper to stabilize it then removed the engine, trans etc as normal. just as precautions, when i worked under the car there were jack stands under suspension and rear bumper.
EdwardBlume |
Jun 1 2016, 07:34 AM
I use 10x10 wood blocks under the wheels. Lots of room for floor jacks and lowering the motor.
r_towle |
Jun 1 2016, 07:47 AM
I cut the car in half first....right in front of the firewall.
rgalla9146 |
Jun 1 2016, 10:18 AM
Advanced Member Group: Members Posts: 4,569 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
If it breaks at the jack point area I'd use four jackstands.
Two under the body at the front engine bar mounts and one at each rear corner. If the front remains on the ground that's just fine. Remove the drivetrain in the conventional way safely. Sawsall work is often unsafe and unpredictable. My .02 cents |
Gunn1 |
Jun 1 2016, 01:32 PM
Senior Member Group: Members Posts: 1,021 Joined: 14-February 16 From: Minnesota Member No.: 19,670 Region Association: None |
Just did this on one of my 72's
Jacked the vehicle up with 8x8x 6 foot long box stock running long wise, one end Cribbed with 2x4 under crankcase the other end engaging central part of the floor board (directly under tunnel where fuel line runs) set jack stands at rear jack points or wherever you can find some meat in those areas.Then after car is high enough place 10x10x 30" cribs, lower car until the tires are sitting firmly on the cribs, adjusting jack stands accordingly as you lower the car. The idea here is to support the area that is folding. All of this also takes place with the front wheels on the ground and chocked. The rear tires up on the cribs should also be restrained from rolling as well. Once you have this completed take the Jack and long box section out and remove engine / tranny as normal. After completing the drop... individually lift one side enough to pull the jack stand out and put a car ramp under the tire on that side. Then do the same thing on the other side. Unchock the front tires and with a little push the car will roll right down the ramps. |
Tbone425 |
Jun 1 2016, 02:24 PM
Just did this on one of my 72's Jacked the vehicle up with 8x8x 6 foot long box stock running long wise, one end Cribbed with 2x4 under crankcase the other end engaging central part of the floor board (directly under tunnel where fuel line runs) set jack stands at rear jack points or wherever you can find some meat in those areas.Then after car is high enough place 10x10x 30" cribs, lower car until the tires are sitting firmly on the cribs, adjusting jack stands accordingly as you lower the car. The idea here is to support the area that is folding. All of this also takes place with the front wheels on the ground and chocked. The rear tires up on the cribs should also be restrained from rolling as well. Once you have this completed take the Jack and long box section out and remove engine / tranny as normal. After completing the drop... individually lift one side enough to pull the jack stand out and put a car ramp under the tire on that side. Then do the same thing on the other side. Unchock the front tires and with a little push the car will roll right down the ramps. This sounds like a good plan. Still thinking I might just set it down and cut it out. Most of the rear quarters are gone already. I'll post some pics after I get the car in my garage. |
GaroldShaffer |
Jun 1 2016, 02:36 PM
You bought another 914? Group: Benefactors Posts: 7,624 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
keep the doors closed. I run a HEAVY DUTY strap (or two) from the a arms up over the front trunk, to the targa bar and ratchet tight. Once in the air Just follow the usual procedure for dropping a enegine.
I had a 73 on my midrise lift like this for well over two months (maybe longer) before I dropped the engine. |
MartyYeoman |
Jun 1 2016, 06:14 PM
Senior Member Group: Members Posts: 1,520 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
I like Garold's approach. Simple and effective.
Tbone425 |
Jun 1 2016, 06:43 PM
Mike Bellis |
Jun 1 2016, 06:56 PM
r_towle |
Jun 1 2016, 06:57 PM
Take saws all with long metal blade and cut car at firewall all the way across.
Trust me, you will enjoy it. |
dlee6204 |
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
I like Garold's approach. Simple and effective. I like this approach too but...Ready?.....wait for it...the doors won't close. Okay... Use another strap to hold the doors tight. (IMG:style_emoticons/default/laugh.gif) |
GaroldShaffer |
Jun 1 2016, 09:23 PM
I like Garold's approach. Simple and effective. I like this approach too but...Ready?.....wait for it...the doors won't close. find some place solid on each side (if there is any metal left) jack up the side and when the car "bends" open close /slam the door so it will catch. Go to the other side of the car and repeat. While cutting the car in half is fun and all, I find trying to remove the engine & trans easier if the car is whole (what is left of it). I have had parts cars in the past that the doors would not close or catch, here again a nice heavy duty strap to help pull them closed always seemed to work for me. YMMV - good luck |
Tbone425 |
Jun 1 2016, 09:30 PM
Tbone425 |
Jun 3 2016, 10:42 PM
I think you'll be able to dance on the roll bar when I'm done with my safety precautions... Just don't trip over the shop lift arm with a chain looped through the rear window hole :-)
Lo-Fi Version | Time is now: 10th June 2024 - 12:50 AM |
