Blue smoke on start up, and accel. Then goes away. |
carcus |
May 31 2016, 09:33 PM
Member Group: Members Posts: 223 Joined: 16-March 16 From: Colorado Springs Member No.: 19,760 Region Association: Rocky Mountains |
Piston rings? Valve guides? What am I looking at? Car has not been driven in a while. Fresh oil change, new plugs and ignition. Just started using 91 octane. 1976 2.0, fuel injection. Moroso ignition change over.
Right now car is in the shop getting all new rotors, all new wheel bearings, brake master cylinder, brake hoses. Also, fan blower does not work, the levers just move but no fan or air. Suggestions on that? I only want it for defroster and fresh air. |
Dave_Darling |
May 31 2016, 10:28 PM
Good chance it's valve guides. Have someone look at the tailpipe when you coast down from high RPMs with the throttle closed. Smoke there means bad exhaust guides.
Heater on/off is controlled completely by the lever between the seats that has the "DEFROST" label next to it. Pull the lever up, the engine fan should push some warm air into the cabin. Pull it up all the way, the fan should come on. If the fan doesn't come on, the most likely culprit is the switch under the lever. If you get no warm air, check the large heater hoses under the car. --DD |
carcus |
Jun 1 2016, 01:17 AM
Good chance it's valve guides. Have someone look at the tailpipe when you coast down from high RPMs with the throttle closed. Smoke there means bad exhaust guides. Heater on/off is controlled completely by the lever between the seats that has the "DEFROST" label next to it. Pull the lever up, the engine fan should push some warm air into the cabin. Pull it up all the way, the fan should come on. If the fan doesn't come on, the most likely culprit is the switch under the lever. If you get no warm air, check the large heater hoses under the car. --DD Good info, thanks Dave!!! Right now getting the heater lever installed for the appearnace package and new shifter installed at the same time. |
Cairo94507 |
Jun 1 2016, 06:10 AM
Michael Group: Members Posts: 9,811 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Nice. Did you already replace the fuel lines in the tunnel with stainless steel?
carcus |
Jun 1 2016, 04:05 PM
Lo-Fi Version | Time is now: 2nd June 2024 - 12:40 PM |
