I bet you can't guess what this is, one car part being used as another car part |
ChrisFoley |
Jun 2 2016, 12:56 PM
I am Tangerine Racing Group: Members Posts: 7,935 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
We found this while preparing to remove an engine from a customer's car.
It's a necessary component on a 914. The part it's modified from is also a needed component, but unknown if actually off a 914. A sideways thru hole is isn't visible in the pic. It's pretty crusty so I won't be surprised if no one comes close to getting either the current application or the original. (IMG:style_emoticons/default/biggrin.gif) |
brant |
Jun 2 2016, 01:02 PM
914 Wizard Group: Members Posts: 11,640 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
it kinda sorta looks like a deformed and dirty shifter coupling half?
ChrisFoley |
Jun 2 2016, 01:23 PM
It does go under the engine, but not a shift part.
EdwardBlume |
Jun 2 2016, 01:26 PM
It looks like a 13mm bolt with a couple tumors.
jim_hoyland |
Jun 2 2016, 01:49 PM
Get that VIN ? Group: Members Posts: 9,321 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Easy: modified door hinge (IMG:style_emoticons/default/smile.gif)
rhodyguy |
Jun 2 2016, 01:50 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Selector inside of a tail shifter?
dlee6204 |
Jun 2 2016, 03:04 PM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
Clutch cable spacer?
rhodyguy |
Jun 2 2016, 03:17 PM
Missed the no shifter. Is it a torsion bar/ a arm adj?
Gunn1 |
Jun 2 2016, 03:56 PM
Senior Member Group: Members Posts: 1,021 Joined: 14-February 16 From: Minnesota Member No.: 19,670 Region Association: None |
It's the proportioning valve for the brake system.
Looks like it might be off a ford pickup, then repurposed for a 914 ? |
BeatNavy |
Jun 2 2016, 04:06 PM
Don't worry, Eric, I've got this one:
It's the proportioning valve for the brake system. It's NOT a proportioning valve. It's a pressure regulator! (IMG:style_emoticons/default/chair.gif) Or IS it....? |
wndsnd |
Jun 2 2016, 04:21 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
Its got balls on the bottom and threads on the top.
Looks like something I might do..... But have not done yet. No idea... |
Garland |
Jun 2 2016, 04:28 PM
Restoration Fanatic Group: Members Posts: 1,330 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
Spring and stop for the thermostat cable?
r_towle |
Jun 2 2016, 05:13 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Engine mount/ door hinge
EdwardBlume |
Jun 2 2016, 05:17 PM
Shroud vent cover made out of a bolt.
Big Len |
Jun 2 2016, 05:22 PM
Senior Member Group: Members Posts: 1,747 Joined: 16-July 13 From: Edgewood, New Mexico Member No.: 16,126 Region Association: Southwest Region |
Starter.
Mike Bellis |
Jun 2 2016, 05:26 PM
Push rod tube...
bretth |
Jun 2 2016, 05:37 PM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
I think it needs to go back in the toilet.
Brett |
904svo |
Jun 2 2016, 06:10 PM
904SVO Group: Members Posts: 1,118 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
Brake banjo bolt used on braking system
Michael N |
Jun 2 2016, 06:25 PM
Certifiable Group: Members Posts: 1,426 Joined: 6-June 04 From: San Jose, Ca Member No.: 2,164 Region Association: Northern California |
Speedometer angle drive???
ChrisFoley |
Jun 2 2016, 06:36 PM
Lo-Fi Version | Time is now: 11th June 2024 - 06:24 AM |
