> LED for Instrument Lights, Headlights, External Marker, Instrument Lights - BA7s replacement
rothaus
post Jun 4 2016, 12:32 PM
Now Since I now owner of a 914, I thought it would be OK to post here about the LED's I'm selling for the gauge illumination for the 914 and 911 which use the BA7s bulbs.
These are direct replacement and no modification of disassembly of the gauges in needed, just plug and play.
The LED's replace these bulbs
(IMG:http://www.914world.com/bbs2/uploads_offsite/carmagic.us-12404-1465065151.1.jpg)
And the LED's look like this
(IMG:http://www.914world.com/bbs2/uploads_offsite/carmagic.us-12404-1465065152.2.jpg)
Here is the picture of the 914 dash with the LED's
(IMG:http://www.914world.com/bbs2/uploads_offsite/c1.staticflickr.com-12404-1486761898.1.jpg)
Here is the Console with the LED's installed.
(IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-12404-1486761899.2.jpg)
The LED's are available as set or can be ordered individual.
My website is Carmagic.us
I have also the DOT approved LED's for the 7" headlight available.
Here is a picture of them installed in a 944.
(IMG:http://www.914world.com/bbs2/uploads_offsite/carmagic.us-12404-1465065152.5.jpg)
H4 light
(IMG:http://www.914world.com/bbs2/uploads_offsite/carmagic.us-12404-1465065152.6.jpg)
LED light
(IMG:http://www.914world.com/bbs2/uploads_offsite/carmagic.us-12404-1465065153.7.jpg)
Please let me know any questions and comments.
Thanks
Engelbert
Carmagic.us
Replies(1 - 19)
rothaus
post Jun 22 2016, 05:44 AM
I have now a complete external LED set for the 911, that includes the following:
Front:
2 each Side Marker LED's
2 each Side Marker/Turn Signal LED's
Rear:
2 each Rear Brake/Tail light LED's
2 each Back up light LED
2 each Turning Signal LED's
1 Flasher Relay for LED Turning Signal
2 LED's for Turning Signal Indicator in Tach Green
1 Wire with connector for Indicator
1 Installation Instruction
See picture below.
(IMG:http://www.914world.com/bbs2/uploads_offsite/carmagic.us-12404-1466595848.1.jpg)
See them here External LED
I' working now on a set for the 914.
Individual LED's are available now for the Backup Light (White) Brake/Tail light (RED), Side Marker (RED or Yellow depending on the lens.
Thanks
Engelbert
rothaus
post Jul 1 2016, 05:19 AM
The external LED's can now be ordered as pairs for the Backup Light (White) Brake/Tail light (RED), Side Marker (RED or Yellow depending on the lens.
I also have now the set for the 914 completed, including the correct flasher relay and wire setup so the indicator light in the Tach works correct. Easy to install, and instruction is included.
These sets can now be ordered from my website Carmagic.us
The price is the same as for the 911.
Cheers
Engelbert
rothaus
post Aug 9 2016, 07:07 AM
Here a picture with the Euro lenses and the LED's installed.
(IMG:http://www.914world.com/bbs2/uploads_offsite/airboxer.com-12404-1470748066.1.gif)
Cheers
Engelbert
amfab
post Aug 12 2016, 07:56 PM
Hi Engelbert, I would like to order the Dash LEDs for my 914 in vintage white. Can you tell me if these will dim in the same way as the original incandescent lights?
rothaus
post Aug 13 2016, 05:23 AM
QUOTE(amfab @ Aug 12 2016, 09:56 PM) *
The LED's do dim, however, it depends on your switch. some time when they get old they don't dim that good.
Here is a video a customer sent me after he installed the LED's in his 914.
914 LED Dashlights
Cheers
Engelbert
matthepcat
post Oct 4 2016, 01:41 AM
Meat Popsicle
Do the LED turn signals require a load resistor? (To avoid rapid or no blinking)
Do 914's need a new relay for those headlights?
rothaus
post Oct 4 2016, 05:53 AM
QUOTE(matthepcat @ Oct 4 2016, 03:41 AM) *
The turning signal kit includes a new relay which works with the LED's and also a wire kit which is just plug and play.
The headlight LED's don't need a relay, since they use less power then the sealed beam or H4.
Cheers
Engelbert
matthepcat
post Oct 5 2016, 12:53 AM
Meat Popsicle
Thanks! Now that it's getting darker earlier, I am thinking about upgrading my lights for winter. I like the convenience of your packages (rather than ordering a bunch of bulbs and resistors from the big LED sites and hoping I ordered correctly)
amfab
post Oct 5 2016, 09:33 AM
Thanks Engelbert,
The gage lights are a big improvement and dim the way I expected them to with no other modifications.
-Andrew
rgolia
post Oct 5 2016, 09:52 AM
GeoJoe
Just ordered a set. Looking forward to seeing the gauges at night. (IMG:style_emoticons/default/beerchug.gif)
rothaus
post Oct 10 2016, 06:08 AM
Check out these T-shirts.
(IMG:http://www.914world.com/bbs2/uploads_offsite/airboxer.com-12404-1476101323.1.jpg)
View them on Facebook
Coondog
post Oct 23 2016, 05:04 PM
Placed my order.....everything but Fogs will be led..... (IMG:style_emoticons/default/smile.gif)
Korijo914
post Oct 24 2016, 05:17 PM
Hey engelbert,
How much will it cost me to switch the yellow side marker LED's to the bright whites for my euro turn signals ?
I am not using the side markers. I am going to buy a complete 914 set, but I want to switch the yellow, side marker LED's to the bright whites LED'S .
Thanks for your time, engelbert !
David ( korijo 914 ) Cawdrey
Korijo914
post Oct 24 2016, 05:41 PM
Oh, I may want to buy extra sets of the 2 bright whites LED'S. How much will they cost for a set of 2 pair of bright whites LED'S. I may need a few sets of the bright whites, maybe like 6 sets. I will have to count how many pairs I will need for the turn signal buckets I have.
rothaus
post Oct 24 2016, 06:24 PM
QUOTE(Korijo914 @ Oct 24 2016, 07:41 PM) *
David, bright white or yellow for the turning signal are the same price, you can order the bright white separate. Just scroll down http://carmagic.us/External.html Or let me know what and how many you need and we can put together a set.
Thanks
Engelbert
Coondog
post Oct 25 2016, 05:42 PM
QUOTE(Coondog @ Oct 23 2016, 04:04 PM) *
5 minute install........super happy.
rothaus
post Oct 26 2016, 06:32 AM
QUOTE(Coondog @ Oct 25 2016, 07:42 PM) *
If you Happy, I'm Happy.
Thanks for the Feedback
Engelbert
rothaus
post Dec 23 2016, 07:24 AM
I took some pictures last night while I had the 911SC out for a drive.
Here with Low Beams
(IMG:http://www.914world.com/bbs2/uploads_offsite/carmagic.us-12404-1482499440.1.jpg)
Here with High Beams
(IMG:http://www.914world.com/bbs2/uploads_offsite/carmagic.us-12404-1482499441.2.jpg)
Cheers
Engelbert
rothaus
post Aug 31 2017, 11:05 AM
I thought you may like my little video I made about the LED's
https://www.youtube.com/watch?v=SSka8cpew6Q
Cheers
Engelbert
- Lo-Fi Version Time is now: 7th March 2026 - 08:06 PM
