> Electrical Problems
Loser_Cruiser
post Apr 6 2005, 03:11 PM
Looking for some advice. (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif)
I bought a 76 2.0L FI DL 914. It did not run right and most of the electrical was not working also. Well, now I have head, signal, brake, emergency, backup lights, starter and wipers. Horn and trunk light are still an issue.
I removed gas tank and flushed, good shape, replaced gas lines and fuel filter. Replaced plugs. points, condenser, rotor, cap and plug wires, new air filter, changed engine and transmission oil, and filter.
Car started right up and runs very nice. Runs very nice for about 5 minutes and then cuts out like it not getting gas or loading up.
Placed a pressure gauge on the FI today, and it stays at 30-32 psi when primed and running. When the car starts to cut out the pressure is still 30-31 psi. Vacuum lines look good and in the right place.
Car is a California car and loaded with the EGR equipment, EGR pump is removed.
Request some advice on the next hoop to jump thru.
Has good charge and battery. Cleaned fuse box today, has good conductivity on the ground strap. Good charging system and battery. Cleaned FI, good spray!!!
I am going to check the cyl pressure and valve tolerances tomorrow.
Running out of things I know what to look at. H E L P !!!!!!!!
Ian
_________________
Come rescue me!
We’ve got a line in the sky (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif)
Replies(1 - 19)
Rand
post Apr 6 2005, 03:17 PM
Cross Member
I had the same problems. Headlights came on but didn't pop up. Starter wouldn't crank. When I replaced my bad ignition switch the headlights worked again.
Cleaning all of the bulb contacts fixed the turn signals. The worst corrosion was on the contacts inside the rear light assemblies.
SGB
post Apr 6 2005, 03:25 PM
just visiting
Many strange things happen with the battery is sputzo...
Charge it up and try again.
merrill
post Apr 6 2005, 03:31 PM
Dirt Pimp
Sounds like a few issues that I have encountered before (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) The lights could be a multitude, check the relay at each light, check the grounds. My brushes were disconnected inside the actual motor.
As far as rough running, have you checked the injectors? Replaced the fuel filter?
Good luck (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
mihai914
post Apr 6 2005, 03:32 PM
Also you may want to have the injectors cleaned, after 15 years sitting, gum and varnish may have formed. I would first do a good tune-up (points, cap, rotor, wires, plugs and timing), test that the mps holds vacuum and see for the injectors.
TheCabinetmaker
post Apr 6 2005, 03:38 PM
I drive my car everyday
Add a valve adjust to that list too, and new gas if you haven't already.
merrill
post Apr 6 2005, 03:59 PM
Dirt Pimp
Oh, and don't forget to change the gear oil. Buy a cylinder head temp and oil temp and check the wheel bearings and get new springs and shocks and steering wheel and and and (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif)
mihai914
post Apr 6 2005, 04:03 PM
What the hell, just go buy a new boxster it will cost the same (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Loser_Cruiser
post Apr 6 2005, 11:50 PM
Buying the boxster would be nice but unecessary because the problem was that the guy who owned it before me had some crappy alarm installed but he diconected it and it was tied into all the lights and stuff like that. The starter is apparently new and wasnt hooked up so i fixed that. And now that the new rotor and wires are in it runs fairly well too. Thanks for the help though i will probably be asking a who lot more soon. Like how to post pictures?
Seaside6
post Apr 6 2005, 11:56 PM
Make sure the all the fuse contacts are clean. Strange things happen when corrosion sets in. I was sure I needed a new wiring harness. Got some contact cleaner and white grease and life is again good.
mattillac
post Apr 7 2005, 12:27 AM
robots!
QUOTE (Seaside6 @ Apr 6 2005, 09:56 PM)
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif)
clean as many contacts/connectors/sockets as you can and check wires. easy stuff first. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
rhodyguy
post Apr 7 2005, 09:24 AM
important fyi, there is a LARGE ground strap that goes from the rear of the trans to the bottom of the rear trunk floor. check for clean contact and that the strap is in great condition, check the ends. this is a major ground. check the grounds behind the headlight buckets, the wires (brown as are all ground wires) either slip on or are held on with a nut. clean, clean, clean.
k
Loser_Cruiser
post Apr 24 2005, 09:49 PM
I pulled the distributor today and cleaned the injector contact and checked the gap again.
Then checked the valves. All valves were right on.
Ran out of time putting things together. I will finish tomorrow and check the timing and see how it runs.
BMartin914
post Apr 24 2005, 10:34 PM
FAQ at the top of the page. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Jeffs9146
post Apr 25 2005, 08:56 AM
Ski Bum
If you have not replaced or checked the CHT then you havent addressed the problem of it cutting out after 5 min of "perfect" running!
Just my .02!
Jeff
post Apr 25 2005, 09:35 AM
Check the fuel filter, I had a similar issue after starting mine up after PO-Barn storage for several years, the fuel line had crap in it, and after runnning for a few minutes, the crap makes it's way up the line and on to the filter. The car then dies once the filter is clogged enough. then, after the car sits for a bit, some of the crap falls back out of the filter, and allows the car to run for a bit and the situation repeats it's self.
-pull the filter, see if it's dirty, attach a soft line to the end of the fuel line, and put it into a bucket, then run the pump for a minute or two to see if dirt comes out with the gas...
-Good Luck!
Cap'n Krusty
post Apr 25 2005, 10:46 AM
Cap'n Krusty
QUOTE (merrill @ Apr 6 2005, 01:59 PM)
Why would you want to change the gear oil? It doesn't wear out. The Cap'n
Loser_Cruiser
post Apr 26 2005, 11:50 PM
What does the CHT stand for? and where is it?
(IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif)
Loser_Cruiser
post Apr 29 2005, 05:20 PM
OK CHT = > Cylinder Head Temperature sensor.
Will start the troubleshooting guide to Fuel injection this weekend. I appreciate the information on the CHT.
I will keep you posted of the progress. Thanks for your input.
Ben M. where are you?
"Help "O" Ben M, Kanobie, your our only hope."
TravisNeff
post Apr 29 2005, 05:28 PM
I had the same problem coming back from the WCC, changed the filter but it would run for a minute and stop, fuel pump still operable. MPS seems to hold vacuum (don't have a vacuum guage) I haven't checked my CHT, but I will tonight! My last place of speculation is my fuel pump is faulty - or crap in the tank (but after changing the filter I couldn't even make it out of the parking lot - less than a minute.
- Lo-Fi Version Time is now: 12th October 2026 - 07:13 PM
