i need some help w/ part numbers, Beck-Arnley |
bd1308 |
Apr 7 2005, 05:58 AM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
okay, i have these white wiring things with the connector at the end
I need these things (part numbers would help)if possible.... *Pin Release Tool(for getting the wire connector things out) *More wires with connectors Oh and what would you all use for connecting two lengths of wire together in the harness.....currently i use butt connectors....but i dont think thats gonna work long term...anybody got any ideas? |
bd1308 |
Apr 7 2005, 06:02 AM
oops...need to attach pic.
Attached image(s) |
Dave_Darling |
Apr 7 2005, 02:36 PM
Aaah, crap. Iffin I had access to my archives... I have the part numbers listed in there, but can't get to them right now. Perhaps someone saved the info back when I sent it to the Rennlist? Or saved it from the DGI.NET 914 club forum?
--DD |
Jeffs9146 |
Apr 7 2005, 02:48 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
I use a very small screw driver to push the lock pin in while I pull out the wire. It works fairly well!
Jeff |
Aaron Cox |
Apr 7 2005, 02:49 PM
whatcha making?
bd1308 |
Apr 7 2005, 04:24 PM
well i broke my old pin release tool....i dont like using screwdrivers, as i have cracked the connectors before....i personally prefer this tool anyway, as it makes the job effortless....beck arnley rocks!!! (IMG:http://www.914world.com/bbs2/html/emoticons/wub.gif) aaron, I am fixing things for real (on my FI) and I need some wirees....time to break out the soldiering iron....
scotty b |
Apr 7 2005, 06:03 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
Check with Radio Shack for the pin remover, I think they keep them in stock, as for connecting the wires, solder and heat shrink! No soldering iron, get one at Radio Shack when you go for your pin remover (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Never used one?Strip the two wire ends, twist them together (place one on top of the other in line and twist) Heat it up until you solder melts on it, place the tip on the center of the wire ends, place your solder at the end and when it begins to melt it will flow into the wire strands, slide your heat shrink over and heat to shrink. (don't hold a flame directly on it!)
Dave_Darling |
Apr 7 2005, 06:51 PM
OK, some Googling turned up the following:
2-pin Shell . . . . 158-0002 . . . . Box of 5 3-pin Shell . . . . 158-0003 . . . . Box of 5 4-pin Shell . . . . 158-0004 . . . . Box of 5 Pins . . . . . . . .158-0005 . . . . Box of 25 Hope this helps... --DD |
Lo-Fi Version | Time is now: 8th June 2024 - 09:16 AM |
