| Splash440 |
Jun 20 2016, 11:07 AM
Newbie ![]() Group: Members Posts: 1 Joined: 5-June 16 From: North Carolina Member No.: 20,071 Region Association: None |
Can someone direct me to the torque values for a 901 tail shifter. I know the speedo drive nut and main shaft nut are 80 ft/lbs, but do not know the others. For example, the shift fork nuts.
Any help would be greatly appreciated. |
| 76-914 |
Jun 20 2016, 02:22 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,880 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Can someone direct me to the torque values for a 901 tail shifter. I know the speedo drive nut and main shaft nut are 80 ft/lbs, but do not know the others. For example, the shift fork nuts. Any help would be greatly appreciated. In general, 8mm bolts call for 14.7 ft/lbs, but 18-19 is OK. 10mm fasteners use about 35 ft/lbs, and 12mm use 56 or so. |
Lo-Fi Version | Time is now: 29th April 2026 - 10:03 PM |
