| maddog |
Jun 25 2016, 09:15 AM
Member ![]() ![]() Group: Members Posts: 200 Joined: 19-May 03 From: Grand Rapids Michigan Member No.: 710 Region Association: None
914-6 OEM replica motor mount designed by Original Customs and manufactured by Maddogs Motor Sports. This mount will fit up to the 3.2 liter flat six and works with early and late cars. BE AWARE that the mount uses the WEVO 911 Sport mount that is sold separately. The retail price on my website is $350, I have 10 available so here is the price breakdown:
5 buyers $300 shipped here is the group buy status so far: 1. Colingreene 2. Flyer86d 3. Mastercylinder 4. Raynekat 5. 914outlaw 6. Mikey914 this group buy will close this Friday August 19 for the $300 price. Those that are on the list so far pm me your paypal emails and I will paypal invoice you. These are ready to ship so as soon as I receive payment they will ship UPS ground. This wiring is on a 75/76 chassis. 70-74 cars will route MUCH better. The hole in the shelf was moved towards the center of the car in the late bodies. ![]() ![]() |
| mb911 |
Jun 25 2016, 11:30 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,694 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
This is a great deal for folks. I just made 3 sets for myself and 1 member and I wouldn't even consider selling them for this price.. Nice job |
| colingreene |
Jun 29 2016, 03:18 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 749 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
I am in for one for T.Hartline.
| flyer86d |
Jun 29 2016, 06:04 PM
Member ![]() ![]() Group: Members Posts: 474 Joined: 12-January 11 From: Corea, Maine Member No.: 12,585 Region Association: North East States |
Can the engine mount portion be used with a stock -6 chassis mount? Reason, I would like a seperate engine mount for the hot rod motor and keep the stock with the original.
Charlie |
| maddog |
Jun 30 2016, 05:57 AM
Charlie, I believe it can, LukeM is using the WEVO mount and plate in place of his stock rubber mount and had to put a 6mm shim because the wevo is shorter than the stock one so I think you would be ok? Maybe Mark D can confirm this?
Can the engine mount portion be used with a stock -6 chassis mount? Reason, I would like a seperate engine mount for the hot rod motor and keep the stock with the original. Charlie |
| mb911 |
Jun 30 2016, 11:26 AM
Charlie, I believe it can, LukeM is using the WEVO mount and plate in place of his stock rubber mount and had to put a 6mm shim because the wevo is shorter than the stock one so I think you would be ok? Maybe Mark D can confirm this? Can the engine mount portion be used with a stock -6 chassis mount? Reason, I would like a seperate engine mount for the hot rod motor and keep the stock with the original. Charlie I would agree it should be no problem if it were setup for the stock rubber mount or the wevo it should work just fine for you. As I said I am knee deep in making some for friends and family ☺ and having looked at factory stuff I am confident it will work for your needs |
| raynekat |
Jun 30 2016, 01:29 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,170 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest
Curious with all of these aftermarket engine mounts, it seems like the snorkel that runs the back end wiring is always in a bind, contorted, twisted, etc.
Is this a problem? I've got the other style 914-6 engine mount (Velios type) and I'm working this out as we go. How to get the snorkel to smoothly and nicely get past these non factory engine mounts..... |
| Luke M |
Jun 30 2016, 05:17 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,443 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States
[quote name='maddog' date='Jun 30 2016, 04:57 AM' post='2365813']
Charlie, I believe it can, LukeM is using the WEVO mount and plate in place of his stock rubber mount and had to put a 6mm shim because the wevo is shorter than the stock one so I think you would be ok? Maybe Mark D can confirm this? [quote name='flyer86d' post='2365659' date='Jun 29 2016, 04:04 PM'] Can the engine mount portion be used with a stock -6 chassis mount? Reason, I would like a seperate engine mount for the hot rod motor and keep the stock with the original. Charlie You will need a 6 mm spacer if you are planning on using a Wevo mount/adapter plate with a factory 914-6 firewall and engine mount. I purchased the Wevo mount and adapter plate from Dave/Mark. I noticed right away that there was a height difference between the factory rubber mount and the Wevo. I measured the two side by side and the Wevo was 6 mm shorter then the factory 6 part. I plan on making up a 6 mm spacer that would go between the lower side of the Wevo mount and the top of the factory 6 engine mount. That should fix the height problem. I do not know if Mark added the 6 mm difference on his engine side mount? That would be a question that he would need to answer. Hope this helps out the factory 6 guys looking to replace a worn out/damaged rubber engine mount. |
| flyer86d |
Jun 30 2016, 05:36 PM
OK, thanks for the input. Based on that, add me to the list for one. I only need the engine portion but I will purchase the whole thing and add the firewall piece to my collection of parts to build another one.
Charlie |
| maddog |
Jul 13 2016, 08:11 AM
1. Colingreene 2. Flyer86d 3. Mastercylinder 4. Raynekat 5. 914outlaw 6. Mikey914 see original post above |
| raynekat |
Jul 13 2016, 05:45 PM
I'd need a better pic of how the snorkel weaves through this new mount before I'd be a buyer and join the group.
Most of the after market mounts don't make it easy for the snorkel and wiring to get from the tunnel into the engine compartment. Plus is it certain the factory rubber mount and upper/lower plates fit with this new mount? ...in case you don't want to go the Wevo route? |
| McMark |
Jul 14 2016, 12:28 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
Raynekat, what year is your car?
70-74 are just like the original 914-6 and they won't interfere. 75-76 cars have the snorkel in the location pictured above and you have to make adjustments or run it like the picture above. |
| MasterCylinder |
Jul 23 2016, 02:42 PM
Newbie ![]() Group: Members Posts: 7 Joined: 5-November 15 From: California Member No.: 19,335 Region Association: Southern California |
I will take one.
| raynekat |
Jul 23 2016, 03:36 PM
Raynekat, what year is your car? 70-74 are just like the original 914-6 and they won't interfere. 75-76 cars have the snorkel in the location pictured above and you have to make adjustments or run it like the picture above. Mine is a 1971. Guess I need to know if the factory rubber mount with the 2 sandwich plates will work with your two pieces? |
| McMark |
Jul 23 2016, 04:23 PM
That's what it was designed to work with. Let me just confirm one measurement first though. I'll respond tomorrow.
| McMark |
Jul 24 2016, 09:53 AM
Confirmed the measurement. Should work just fine with a stock mount.
| raynekat |
Jul 26 2016, 01:25 PM
OK, then put me down as part of the group buy. I'll be trading in that other mount that you PM'd me about. I'll hang on to mine until the group buy is official.
| maddog |
Jul 28 2016, 06:22 AM
| maddog |
Aug 3 2016, 05:00 AM
| forrestkhaag |
Aug 8 2016, 04:41 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region |
Lo-Fi Version | Time is now: 7th December 2025 - 01:39 PM |
