WTB- parts needed for L-jetronic retrofit, going from carb back to Ljet |
jmitro |
Jun 25 2016, 10:42 PM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
Engine number EC006075. Chassis is a 1974 US model.
I need all parts to convert back from single carb to L-jetronic. From my research, this would include AFM, ECU, airbox, harness, fuel injectors, cold start valve, FPR, fuel pump, filter, hoses. Give me price shipped to 73064 thanks |
JTdevine |
Jun 25 2016, 11:31 PM
Newbie Group: Members Posts: 31 Joined: 25-September 13 From: bothell,wa. Member No.: 16,435 Region Association: Pacific Northwest |
Engine number EC006075. Chassis is a 1974 US model. I need all parts to convert back from single carb to L-jetronic. From my research, this would include AFM, ECU, airbox, harness, fuel injectors, cold start valve, FPR, fuel pump, filter, hoses. Give me price shipped to 73064 thanks I think i have most of the parts you are looking for ill check if you are still intresred let me know. Jason |
bdstone914 |
Jun 26 2016, 02:57 AM
bdstone914 Group: Members Posts: 4,536 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Also the AFM boot, air cleaner bracket that bolts to the car, resistor pack. I should have those if the first person does not. 75 and 74 have many parts that are not the same. Best to get a near complete system.
Bruce |
jim_hoyland |
Jun 26 2016, 06:27 AM
Get that VIN ? Group: Members Posts: 9,318 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
(IMG:style_emoticons/default/agree.gif) '74 and '75 are slightly different; be sure the ECU, AFM and FI harness are compatibile.
Good luck with the project, you'll have a reliable system when completed |
jmitro |
Jun 26 2016, 06:53 AM
Yes definitely interested in what you guys have. Let me know.
I understand 74 and 75 may not be compatible. Can someone confirm that my engine number corresponds to a 74 version and not 75? Also....the ECU I need is 473 906 021? |
davep |
Jun 26 2016, 07:11 AM
914 Historian Group: Benefactors Posts: 5,152 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Engine number EC006075 is a 1974 serial #.
mapguy |
Jun 26 2016, 09:35 AM
Freelance Generalist Group: Members Posts: 90 Joined: 31-January 14 From: Inland Empire, CA Member No.: 16,945 Region Association: Southern California |
I have 2 complete sets of L-Jet I'd be willing to part with. One appears to be a '74, and one a '75.
Part of that is a set of grey injectors gone through by RC engineering. PM me if interested. I'll make you a deal on the whole shootin' match. Jeff |
bdstone914 |
Jun 26 2016, 11:21 AM
The 75 is compatible to a 74 engine. You just need the right set of parts. 75's have a seven pin connector on the AFM for the added temp sender. The boot is also different on the size of the vent hose. 914 Rubber may be remaking them. Most are cracked and broken.
mapguy |
Jun 26 2016, 12:17 PM
Bruce, as per usual, is right.
Other problem areas are the plenum seal and the breather tower seals. I got most of the seals new from 914rubber and will include whatever I have. |
Dominic |
Jun 26 2016, 01:01 PM
Dominic Group: Members Posts: 992 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California |
If you need the air filter bracket that bolts to the car, let me know. $15.00 shipped
Attached thumbnail(s) |
worn |
Jun 26 2016, 01:27 PM
can't remember Group: Members Posts: 3,163 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Claus Graf |
Jun 26 2016, 03:53 PM
Member Group: Members Posts: 51 Joined: 25-November 14 From: Houston, TX Member No.: 18,154 Region Association: None |
I'm in Houston and I have a 1974 914 1.8 that I'm rebuilding (been fighting with the rust for 3 years). I'm planning to swap to a carburetor to make things easier. What carburetor and manifold does your car have?
Regards Claus |
jmitro |
Jun 26 2016, 08:11 PM
I'm in Houston and I have a 1974 914 1.8 that I'm rebuilding (been fighting with the rust for 3 years). I'm planning to swap to a carburetor to make things easier. What carburetor and manifold does your car have? Regards Claus It's a single Weber carb and intake manifold. From what I've read it's not a good setup for the stock engine. |
Lo-Fi Version | Time is now: 7th June 2024 - 10:12 PM |
