| TX914 |
Jul 1 2016, 06:14 AM
Alan-B ![]() ![]() Group: Members Posts: 177 Joined: 27-July 14 From: USA Member No.: 17,689 Region Association: None
Went for a short run around the neighborhood and stopped for gas. When I restarted there was a terrible scraping noise so I shut it off immediately. Sounded to me like a piece of engine tin or casing scraping on the impeller…
Tried restarting a couple of times with same result. Clutch in/out made no difference, and I was afraid to rev it. Oil level okay, and nothing loose in/around the impeller. I decided to drive it gently away to the side so I could tow it home for closer inspection. Restarted and drove in reverse for a few feet which made no difference, but then pulling forward for a few feet the scraping suddenly stopped. All seemed normal again so I drove it home – it idled fine, had good power and haven’t heard the noise since. I’m looking for ideas as to what the scraping sound might have been. Anyone experienced that before? It’s a ’76 with stock FI 2.0. It does have a relatively new starter. |
| ThePaintedMan |
Jul 1 2016, 06:17 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,887 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States
Make sure there is nothing down by the impeller. Debris, etc does happen from time to time. Also make sure it wasn't the coil vibrating loose and rubbing against the impeller (BTDT).
Finally, check the torque on the impeller bolts and make sure it's not walking out of the "cage". |
| stugray |
Jul 1 2016, 06:31 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
"New Starter"?
Is it a stock starter or an after market? Could it have been stuck engaged with the flywheel? That makes an odd noise. The aftermarket high torque starters require a shim |
| TX914 |
Jul 1 2016, 08:06 AM
George, Thanks for the ideas. Flashlight and mirror reveals nothing out of place around the impeller and impeller seems tight although I should remove alternator belt to be sure. I suppose re-torquing the impeller is a good excuse to drop the engine. (IMG:style_emoticons/default/smile.gif)
| TX914 |
Jul 1 2016, 08:12 AM
Stugray, that's a stock starter (SR17x I think) - installed < 1K miles. I suppose it's possible it failed to disengage, although this did not sound like the type of grinding one hears when re-engaging on a moving flywheel. This was more of a scraping sound...
| TheCabinetmaker |
Jul 1 2016, 10:17 AM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,378 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I experienced that exact same thing two weeks ago. Terrible screech then nothing when engine started. Drove home twenty miles. Turned out to be the bushing and retainer on the front off the starter came off lodging in the bell housing with the clutch. Fortunately no damage was done except that poor brass bushing. Might be worth checking.
| TX914 |
Jul 1 2016, 10:49 AM
Thanks for the reply. Will definitely check that out!
| injunmort |
Jul 1 2016, 05:51 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
i experienced the same situation, make sure your engine is tight to the bar and the bar is tight in the mounts. mine was so loose , the engine would move forward squeezing the the tin in and scrape the impeller and belt against it. it made a heart stopping racket.
| TX914 |
Jul 3 2016, 06:20 AM
i experienced the same situation, make sure your engine is tight to the bar and the bar is tight in the mounts. mine was so loose , the engine would move forward squeezing the the tin in and scrape the impeller and belt against it. it made a heart stopping racket. Thanks for the suggestion. I'll check that also. |
| TX914 |
Aug 15 2016, 03:29 PM
Finally got time to remove the starter to see if the scraping was perhaps due to the brass bushing coming loose as reported by the CabinetMaker (Curt?). Nothing amiss that I can see. This is a relatively new SR17X. Am I missing something?
. Oh, and engine bar is tight in the mounts. |
| r_towle |
Aug 15 2016, 06:10 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Maybe I'm getting old , well ok...I am. That starter looks wrong to me
| TheCabinetmaker |
Aug 15 2016, 06:23 PM
I'm old too, but starter looks right to me. What do you see wrong Rich?
| Garland |
Aug 15 2016, 07:54 PM
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,431 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest
Fan belt frayed, slapped, and a peice flew off? Check the belt closely.
| porschetub |
Aug 15 2016, 08:32 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,142 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
what ever was causing the noise has spat out hopefully,t4's are dirty buggers suck in all sorts he he, do check your altenator as mentioned,could be a bad belt or it has a semi seized bearing...happens.
Lo-Fi Version | Time is now: 26th July 2026 - 11:29 AM |
