Is this an early or late adapter?, Steering wheel question |
jrblackbox |
Jul 2 2016, 03:48 PM
Member Group: Members Posts: 285 Joined: 8-September 15 From: Easton, CT Member No.: 19,140 Region Association: None |
GaroldShaffer |
Jul 2 2016, 08:12 PM
You bought another 914? Group: Benefactors Posts: 7,623 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
Based on the cancel ring on it I would say late. Is there a part number on it? Momo 8002 are late style. 8000 are early .
Valy |
Jul 2 2016, 11:55 PM
Senior Member Group: Members Posts: 1,676 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
We need a side view and length measurement.
jrblackbox |
Jul 3 2016, 04:57 AM
We need a side view and length measurement. It is 2.5" the only mark I could find on it is on the side K94, other that Made in Italy. Attached thumbnail(s) |
jrblackbox |
Jul 3 2016, 11:50 AM
This adapter doesn't seem to fit my early.
dlkawashima |
Jul 3 2016, 02:14 PM
914 Guru Group: Members Posts: 9,749 Joined: 1-October 10 From: San Jose Member No.: 12,234 Region Association: Northern California |
What's wrong? Is it the spline pattern? Is there a big gap between the hub and the column?
BTW, I believe Raid steering wheels use the 74mm Nardi bolt pattern rather than the 70mm Momo. (IMG:http://www.914world.com/bbs2/uploads_offsite/stebok.net-12234-1467576845.1.jpg) |
stevegm |
Jul 3 2016, 02:30 PM
Advanced Member Group: Members Posts: 2,111 Joined: 14-July 14 From: North Carolina Member No.: 17,633 Region Association: South East States |
I've got the same issue. I have a hub that is supposed to be for an early car. But there ends up being a large gap between the hub and column. It won't slide past the clip at the end of the spline. I guess I need one that has the part that slides over the spline further up in the hub a deeper hub). Is your car an early? Ours is a '72.
Attached image(s) |
dlkawashima |
Jul 3 2016, 02:47 PM
jrblackbox |
Jul 3 2016, 02:49 PM
What's wrong? Is it the spline pattern? Is there a big gap between the hub and the column? BTW, I believe Raid steering wheels use the 74mm Nardi bolt pattern rather than the 70mm Momo. (IMG:http://www.914world.com/bbs2/uploads_offsite/stebok.net-12234-1467576845.1.jpg) It fits on the spline,but there is a 1/2" gap when pushed on all the way. It also looks like the signal light canceller is not long enough.. |
dlkawashima |
Jul 3 2016, 03:19 PM
Sounds like you both have the same problem. There is an early adapter (supposedly) on Ebay that's reasonably priced - $48.50. I have no experience with it or the seller ... just passing the information along. Works for both Nardi and Momo bolt patterns:
http://www.ebay.com/itm/Steering-Wheel-Ada...%3D321268596015 |
jrblackbox |
Jul 3 2016, 03:33 PM
Sounds like you both have the same problem. There is an early adapter (supposedly) on Ebay that's reasonably priced - $48.50. I have no experience with it or the seller ... just passing the information along. Works for both Nardi and Momo bolt patterns: http://www.ebay.com/itm/Steering-Wheel-Ada...%3D321268596015 might have to try it. |
jrblackbox |
Jul 9 2016, 04:31 PM
Sounds like you both have the same problem. There is an early adapter (supposedly) on Ebay that's reasonably priced - $48.50. I have no experience with it or the seller ... just passing the information along. Works for both Nardi and Momo bolt patterns: http://www.ebay.com/itm/Steering-Wheel-Ada...%3D321268596015 Tried this one but didn't work. |
jrblackbox |
Jul 9 2016, 04:36 PM
Lo-Fi Version | Time is now: 28th May 2024 - 11:31 PM |
