| DavidSweden |
Jul 9 2016, 11:42 AM
Member ![]() ![]() Group: Members Posts: 481 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
I got myself a 911 reflektor which I was planning on mounting on the back end of my 914. Unfortunately its too long to fit between the tail lights
Did I get the wrong one or do they need cutting? (IMG:http://www.914world.com/bbs2/uploads_offsite/i1300.photobucket.com-17452-1468086162.1.jpg) |
| Mike Bellis |
Jul 9 2016, 11:45 AM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
Needs to be cut. They all do.
| Dion |
Jul 9 2016, 11:50 AM
RN ![]() ![]() ![]() ![]() Group: Members Posts: 2,926 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region
Custom cut fit by you :-). There were a few back in the 80's made to fit
the 914 (aftermarket) obviously. There a few out there. I sold mine recently that was made for the 914 with the electric lock. Take your time and seal the ends with epoxy for the 911 ones so condensation won't get in between the layers of plastic and reflective material. Good luck. |
| DavidSweden |
Jul 9 2016, 11:56 AM
| DavidSweden |
Jul 9 2016, 11:57 AM
Custom cut fit by you :-). There were a few back in the 80's made to fit the 914 (aftermarket) obviously. There a few out there. I sold mine recently that was made for the 914 with the electric lock. Take your time and seal the ends with epoxy for the 911 ones so condensation won't get in between the layers of plastic and reflective material. Good luck. Thanks |
| mepstein |
Jul 9 2016, 12:04 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,587 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Around here, a nice 911 reflector sells for $300.
I used to like the look on a 914. Now, not so much. I definitely don't like the holes it leaves in the metal. |
| Mikey914 |
Jul 9 2016, 12:15 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
If you look at Carys thread on my car you can see the rust damage it caused on mine. Wound up replacing the entire rear end.
| SirAndy |
Jul 9 2016, 01:06 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Have members advice for the best way to cut it and mount it, it was not cheap so I dont want to mess it up.... If you cut off the mounting studs you might be able to just glue it on with double sided tape instead of drilling holes in your panel. Not sure how that would work with the curvature of the reflector, might need some heat and pressure to get it straight first. (IMG:style_emoticons/default/idea.gif) |
| matthepcat |
Jul 9 2016, 02:01 PM
Meat Popsicle ![]() ![]() ![]() Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
I have one I pulled off my car you can have. Some of the mounting tabs were broken and the PO did some DIY wood/glue repairs to it....but will give you a guide
I highly suggest mounting it without drilling huge holes in your body. |
| mepstein |
Jul 9 2016, 02:25 PM
I have one I pulled off my car you can have. Some of the mounting tabs were broken and the PO did some DIY wood/glue repairs to it....but will give you a guide I highly suggest mounting it without drilling huge holes in your body. I just shipped a small box to Sweden - $45. The reflector is probably more. |
| Chris914n6 |
Jul 9 2016, 02:43 PM
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,528 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
When I get off work I'll take some pics. I bought a car with that reflector mounted. Big holes. Not something I would have done myself. The aftermarket 914 reflector is 6 small screw holes.
| matthepcat |
Jul 9 2016, 04:14 PM
Wow, I guess I didn't realize he was in Sweden!
| Larmo63 |
Jul 9 2016, 06:12 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,267 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
I'd be lying if I said I like these. I don't.
I wouldn't even put one on my garage wall. (IMG:style_emoticons/default/stirthepot.gif) |
| bandjoey |
Jul 9 2016, 06:37 PM
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,935 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Get some LED light strips behind it and mount it on the shop wall (IMG:style_emoticons/default/piratenanner.gif)
| SirAndy |
Jul 9 2016, 07:04 PM
Wow, I guess I didn't realize he was in Sweden! DavidSweden should have been a hint ... (IMG:style_emoticons/default/biggrin.gif) |
| Rand |
Jul 9 2016, 07:28 PM
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,414 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
I always likened these things to Porsche stickers.
I mean, would you add it to your NARP if it didn't have the Porsche name painted on it?? Because reflectors are cool? Or, is it truthfully, a sticker to boast about ARP? When I was a kid, the first thing I removed from my bicycles were the stupid reflectors. (Oh wait, maybe I'm missing a market opportunity! I could sell Porsche reflectors to fit 914 wheels! And maybe PMB will help me engineer a card holder to flappatappatap in the spokes of the fuchs!) There are some other nice Porsche stickers too. You can get it on the rocker panels, across the top of the windshield, badge it on the hood.... Ok, joking and snarking over. (IMG:style_emoticons/default/beerchug.gif) |
| SixerJ |
Jul 10 2016, 02:07 AM
Member ![]() ![]() Group: Members Posts: 451 Joined: 24-June 13 From: UK Member No.: 16,042 Region Association: England |
I have a genuine 914 version that came off my six (it's not going back on either)
I'm currently up north for the weekend, when I get home I will post pics of the holes in the rear panel and reflector. As others have said big holes, but no rust issues as a result |
| RickS |
Jul 10 2016, 09:07 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
I'd be lying if I said I like these. I don't. I wouldn't even put one on my garage wall. (IMG:style_emoticons/default/stirthepot.gif) Couldn't agree more, but since I am a cheap bastard, I just blacked it out. But different strokes and all that. ![]() |
| Drums66 |
Jul 10 2016, 11:19 AM
914 Rudiments ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
.......As stated they are all cut down!......How many times do you have to have the name on a car?....1 2 3 4 (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/confused24.gif)
| barefoot |
Jul 10 2016, 11:33 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,488 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States
Here's one on E-Bay apparently cut to 914 length:
http://www.ebay.com/itm/Porsche-914-Heckel...2rW&vxp=mtr |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:07 PM |
