Clutch Problems |
Clutch Problems |
cal914 |
Jul 10 2016, 12:32 PM
Member Group: Members Posts: 319 Joined: 12-April 12 From: United Kingdom Member No.: 14,366 Region Association: None |
When putting my 1970 914 into gear lately i'm having to push the clutch almost through the floor ,what could be causing this its only be happening the last couple of trips
Thanks Brian |
era vulgaris |
Jul 10 2016, 01:00 PM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
It's probably that your clutch cable is stretching, or the adjuster nut has come loose.
Easy fix. Tighten the adjuster nut a few turns, and then see how it feels. Make sure you have a jam nut on there too. |
Jeffs9146 |
Jul 10 2016, 01:24 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
Check your clutch cable tube at the firewall!
rgalla9146 |
Jul 10 2016, 04:08 PM
Advanced Member Group: Members Posts: 4,564 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
and in the tunnel
rgalla9146 |
Jul 10 2016, 04:37 PM
[quote name='Jeffs9146' post='2369805' date='Jul 10 2016, 03:24 PM']
Check your clutch cable tube at the firewall! [/quote Double |
Lo-Fi Version | Time is now: 4th June 2024 - 07:02 AM |
