Fuel line grommets, Can't find |
Cornerlot |
Jul 12 2016, 07:50 AM
Member Group: Members Posts: 89 Joined: 4-June 16 From: New Braunfels, TX Member No.: 20,070 Region Association: Southwest Region |
I'm new to 914's, previously I've just fooled with 911's.
I now have a '70 914-6 with the fuel tank out and need to replace the rubber grommets for the fuel lines. These are where the 2 fuel lines (different O.D.'s) enter the tunnel under the tank, both going through their own OVAL holes (one line per hole). Any ideas? The closest I found are the PN 111957861 oval grommets for the brake reservoir lines and fuel in the 914-4 engine bay. The PET shows both a NLA single large oval grommet in some cars set up for 2 lines, or a un-pictured NLA grommet PN 99970209550 for single lines. Steve |
napasteve |
Jul 12 2016, 08:34 AM
914 driving winemaker Group: Members Posts: 504 Joined: 2-January 13 From: Napa, CA Member No.: 15,327 Region Association: Northern California |
altitude411 |
Jul 12 2016, 08:57 AM
I drove my 6 into a tree Group: Members Posts: 1,306 Joined: 21-September 14 From: montana Member No.: 17,932 Region Association: Rocky Mountains |
Mark carries these 10 mm as well as 8 mm.
http://shop.914rubber.com/Fuel-line-grommet-10mm-10mmFLG.htm |
Rotary'14 |
Jul 12 2016, 10:03 AM
Senior Member Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 |
Hi,,
914-6 has front grommets similiar to the engine shelf grommets. I have those available at $4 each plus shipping. -Robert |
Mikey914 |
Jul 12 2016, 10:36 AM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Yep, I have the rear ones. If you can't find what you need. I can probably make it. Just let me know.
Attached thumbnail(s) |
Cornerlot |
Jul 12 2016, 11:24 AM
Yep, I have the rear ones. If you can't find what you need. I can probably make it. Just let me know. The round ones won't work, they are larger and oval. The engine shelf ones may work. Right now I have the stock lines, so angled 8mm and 10mm should work. Steve |
Cornerlot |
Jul 12 2016, 11:26 AM
Your 914-6 setup is different than my 73 2.0 pictured below. I reused my single big grommet when installing SS lines; it was in good condition. You might contact Chris at Tangerine Racing. He may be able to help you. That 914-4 grommet is larger than my single line grommets. The dual line one is NLA any ways. Steve |
Cornerlot |
Jul 12 2016, 11:36 AM
A picture before they fell apart ...
Dave_Darling |
Jul 12 2016, 05:06 PM
Those do look an awful lot like the engine shelf grommets.
--DD |
Mikey914 |
Jul 13 2016, 12:34 AM
Well I have these, which I think you may be referring to. They are the larger ID
http://shop.914rubber.com/Vent-hose-bushin...99970204950.htm Attached image(s) |
Mikey914 |
Jul 13 2016, 12:38 AM
Cornerlot |
Jul 13 2016, 08:10 AM
Mikey914 |
Jul 14 2016, 12:28 AM
thanks Steve,
They are elliptical, the angle of the photo is distorting the perspective. Yes my photography sucks. |
Lo-Fi Version | Time is now: 31st May 2024 - 07:15 PM |
