mrfourteen |
Member ![]() ![]() Group: Members Posts: 74 Joined: 1-November 13 From: Oregon out in the Mozarks Member No.: 16,596 Region Association: Pacific Northwest ![]() |
Most of whats needed to swap a Toyota 4AG int a 914. This will fit without cutting the car up with enough room for the radiator in the engine bay.
Kennedy adapter and flywheel uses VW clutch and 914 T/O bearing. Included are the following. 1.6 twin cam 16 valve 4AG engine from RWD GTS Carolla Rowland intake and Weber synchronous 38/38 "Outlaw" carb. Internal regulated alternator with new belt 914 side shift transaxle Kennedy adapter plate and starter New clutch, pilot bearing and Sachs T/O bearing.(flywheel is new unused) New aluminum radiator with electric fan, Toyota oil cooler with electric fan. EDIS ignition components (crank pulley has been turned to accept trigger wheel) Stainless low mount turbo header. Steel merged header for non turbo application. Pair of temp. engine mounts The engine has new timing belt, oil filter and water pump and is equipped with t-stat controlled oil cooler circut. OEM spare oil filters This set up should make about 120 HP. If you know 4AG engines you probably can see the potential in this swap. If not do a little research. My plan was to use this engine to sort out the install then switch to a 20 valve version of the 4AG (they make 190ish HP) Simple install with minimal wiring and fuel delivery to sort. $914.11 offers/ trades I'll post more photos on craigslist here is a link http://portland.craigslist.org/grg/pts/5684311773.html ![]() ![]() ![]() |
mrfourteen |
bump up
Rotary'14 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 ![]() |
Would you be interested in a Subi 6 cylinder (EZ30D) with un cut wiring harness,ECU and sensors in trade?
mrfourteen |
Thanks but if I could do a swap it would be the 4AG It would be an easy swap with this package.
I just can't do this now. (or ever) Too bad I did a 4AG in my MGB GT and it was amazing. Have a look. http://oppositelock.kinja.com/this-twin-ca...time-1613365867 |
mrfourteen |
back to the top
euro911 |
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California ![]() ![]() |
Would you be interested in a Subi 6 cylinder (EZ30D) with un cut wiring harness, ECU and sensors in trade? Hey, what you got there, Robert? (IMG:style_emoticons/default/popcorn[1].gif) |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
Thanks but if I could do a swap it would be the 4AG It would be an easy swap with this package. I just can't do this now. (or ever) Too bad I did a 4AG in my MGB GT and it was amazing. Have a look. http://oppositelock.kinja.com/this-twin-ca...time-1613365867 Dang, very nice MGB GT, great job. The 4AG looks like it would be a neat swap into a 914, killer price for all that, someone is going to get a great deal. Hopefully they post pics once done (it's screaming for ITB's or side draft Webers) |
euro911 |
Korijo914 |
Newbie ![]() Group: Members Posts: 24 Joined: 26-April 16 From: Snohomish WA Member No.: 19,940 Region Association: None ![]() |
Mrfourteen,
I am interested in your Toyota swap. I am north of Seattle, so I will have someone to come down and meet you. What kind of trades are you interested in? Let me know what you like. Thanks for your time! Korijo914 ( David Cawdrey ) |
Mueller |
did this ever find a good home?
ablesnead |
Member ![]() ![]() Group: Members Posts: 157 Joined: 16-September 13 From: United States Member No.: 16,395 Region Association: None ![]() |
it was on craigs list for 850.00 a month ago ..
Lo-Fi Version | Time is now: 16th June 2024 - 10:49 PM |
