factoryfront & rear sway bars, bushings |
morph |
Apr 11 2005, 12:06 AM
quality parts builder Group: Members Posts: 1,828 Joined: 25-November 03 From: oregon coast Member No.: 1,389 Region Association: Pacific Northwest |
i have a complete front & rear sways im goingto be installing on one of my cars,i need to know a source for the bushings .any recomendations for"type"of bushings for them too.(and if youre reading this engman)we will be in touch because the car didnt come with them.
james |
markb |
Apr 11 2005, 12:08 AM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
Call Dave @ GPR. 1 800 321-5432. He knows all that stuff.
skline |
Apr 11 2005, 12:18 AM
I know Pelican sells them, I have a set of rears, used but in good condition. Dont go with the weltmeister unless you want it to squeak. Go with the factory rubber ones. They should last the life of the car. Engman makes all the other parts you will need to install them and do an outstanding job of it too. Both of my cars have his parts all over them.
neo914-6 |
Apr 11 2005, 12:26 AM
neo life Group: Members Posts: 5,086 Joined: 16-January 03 From: Willow Glen (San Jose) Member No.: 159 |
Scott, Do the bushings on 22mm Weltmeister bars squeel? I am about to install one... |
skline |
Apr 11 2005, 12:29 AM
If you groove it and lube it, it should be good but dont use silicone, that will gel up after awhile and will squeak. Use some bearing grease on it and you should be ok. Thats only if it is their urethane bushings. The rubber ones dont have that problem. You can tell the rubber from the urethane, the urethane is like a hard plastic.
Brando |
Apr 11 2005, 03:18 AM
BUY MY SPARE KIDNEY!!! Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
Graphite lube mixed with molybdenum on polyurethane works wonders, check my dad's 25mm sways with welt bushings.
There's also Neoprene (softer but squeak-resistant). And solid/roller bearings (skline, what were they called?), but those'll rattle your teeth out. |
Lo-Fi Version | Time is now: 8th June 2024 - 07:07 PM |
