Any thoughts on this? Apparently they believe new bearings can be improved, Re-grease new sealed dual-row bearing |
mskala |
Jul 29 2016, 02:35 PM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
I saw this and what they are talking about is the type of wheel bearings used in
914 rear. Re-greasing new sealed bearings if racing with them When we buy FAG or SKF bearings for $40 to $80, are they cheaping out on the grease used within? |
zambezi |
Jul 29 2016, 03:03 PM
Senior Member Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States |
Yes I have heard the same thing, maybe even on this site. This guarantees future sales for them.
Mueller |
Jul 29 2016, 03:16 PM
Makes sense to me, the grease installed is spec'd out for general purpose use.
What is really different than your front wheel bearings that you have to grease yourself? I'm sure people with race cars spend a few more dollars on higher quality grease for their unsealed front wheel bearings instead of using cheaper general purpose grease. When I use to order special spindle bearings used in Semiconductor processing equipment we had the option for different grease or oil (in simple terms, grease is really oil with a thickening agent, grease offers more resistance or drag over oil) |
6freak |
Jul 29 2016, 03:30 PM
MR.C Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest |
brant |
Jul 29 2016, 04:01 PM
914 Wizard Group: Members Posts: 11,639 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I wish I had done that on the rear bearing I replaced 4 months ago.... and I also wish I had done that on the rear bearing I used to replace the 4-month old one, about 2 weeks ago.....
Mark Henry |
Jul 29 2016, 04:55 PM
I wish I had thought about this as well, but they are already installed.
On a similar note I've read a few times that clutch release bearings are not serviceable, but I found them quite easy to press apart, clean, regrease with Swepco 101 and press back together. You do need a small press, but in a pinch you could do it with a vice. |
Valy |
Jul 29 2016, 05:02 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
No need to press out the clutch release bearings.
I clean them at high temp in an ultrasonic bath with degreaser. Then I repack them under pressure. Works like magic every time. |
Lo-Fi Version | Time is now: 8th June 2024 - 01:35 AM |
