Location of reverse light switch? |
Dutchdriver |
Aug 4 2016, 03:14 AM
Newbie Group: Members Posts: 38 Joined: 10-May 16 From: Netherlands Member No.: 19,983 Region Association: Europe |
I cant seem to find my reverse light switch. Reverse lights arent working and the one thing I havent checked is this switch. But its like the G spot of my 914...where is it? (IMG:style_emoticons/default/biggrin.gif)
Anyone got a tip or pic? |
oldie914 |
Aug 4 2016, 04:04 AM
Member Group: Members Posts: 102 Joined: 2-May 10 From: Germany Member No.: 11,680 Region Association: None |
Switch is located on the side of the transmission case. It is an off/on switch with 2 connecting wires. Pull the wires and hold them together with the ignition switch on and the backup lights should come on.
To test the switch, take it off and check for continuity between the electrical poles while operating the swith with a small screwdriver. Sometimes the operating pin inside the transmission will wear until it is too short to close the switch. I couldn't find any pictures but could make one if you need it. |
bahnzai |
Aug 4 2016, 05:43 AM
Member Group: Members Posts: 307 Joined: 26-July 06 From: Columbia, SC Member No.: 6,509 Region Association: South East States |
Sorry the picture is not well lite, but as mentioned, it is on the side of the transaxle case (where the arrow is added) and not too bad to get to. Hope that helps. |
Dutchdriver |
Aug 4 2016, 06:33 AM
Guys, awesome. Thats the info I needed. Appreciate it!
catsltd |
Aug 4 2016, 07:03 AM
Member Group: Members Posts: 181 Joined: 7-June 15 From: Calgary Alberta Member No.: 18,814 Region Association: None |
I wish I could find the wires to my back up switch.
Dont even know where to start. |
76-914 |
Aug 4 2016, 07:40 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
look at your 14 pin plug at the relay board. it's in there.
6freak |
Aug 4 2016, 08:31 AM
MR.C Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest |
Lo-Fi Version | Time is now: 8th June 2024 - 09:08 PM |
