914 will not start:, no power to pump |
rw163014 |
Aug 4 2016, 07:09 AM
Newbie Group: Members Posts: 18 Joined: 6-August 06 From: Bedford In. 47421 Member No.: 6,593 |
I have a 914 2.0 Porsche and car would not start. I have checked the pump and pump will run off battery, but not getting power to the pump contact. I have switched relays to pump with no result.
Any ideas on what to do; temp sensor, computer, pressure sensor etc. thanks, sawbones (IMG:style_emoticons/default/sad.gif) |
TheCabinetmaker |
Aug 4 2016, 07:47 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Fuse on relay board good? Take it out and clean fuse and holder
Kansas 914 |
Aug 4 2016, 08:06 AM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
Fuse on relay board good? Take it out and clean fuse and holder (IMG:style_emoticons/default/agree.gif) Always the first place to look. |
rw163014 |
Aug 5 2016, 08:30 AM
Fuse on relay board good? Take it out and clean fuse and holder I only see a 20 amp fuse, blue, that is suppossed to control blower. I don't see an 8 amp fuse that i have seen listed. Am I missing something and can the 20 amp fuse keep the pump from getting power? |
BeatNavy |
Aug 5 2016, 08:48 AM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
That fuse also impacts fuel pump relay. Clean the fuse contacts, inspect fuse, clean / check relays, and make sure the other connections are seated correctly. Assuming all that checks, start checking continuity and connection to ECU.
For reference: (IMG:http://www.914world.com/bbs2/uploads_offsite/bowlsby.net-17042-1470408502.1.jpg) |
cary |
Aug 5 2016, 09:00 AM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
Mines always been the relay. Just reach and switch it with the heater relay and see if it works.
If the relay pins have compacted you can spread them back open with a razor blade or Exacto knife. |
TheCabinetmaker |
Aug 5 2016, 11:07 AM
Original post says relays were swapped with no change. Beat Navy echos my thoughts
Lo-Fi Version | Time is now: 7th June 2024 - 04:28 PM |
