| carcus |
Aug 9 2016, 04:17 PM
Member ![]() ![]() Group: Members Posts: 223 Joined: 16-March 16 From: Colorado Springs Member No.: 19,760 Region Association: Rocky Mountains |
| rhodyguy |
Aug 9 2016, 04:25 PM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Just the cover. Then you'll see the real bumper that lives behind the rubber cover.
| Rand |
Aug 9 2016, 04:27 PM
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,413 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Maybe too soon, but in time, you'll happily get rid of those mega heavy bubs. Then that air dam and everything else will look nicer. (IMG:style_emoticons/default/wink.gif)
| carcus |
Aug 9 2016, 10:14 PM
Just the cover. Then you'll see the real bumper that lives behind the rubber cover. So peel the rubber off the front bumper? Looks like it goes behind the bumper and afraid to peel the front rubber off the bumper. Any DIY for that? Also does it screw in or do I need to drill? Appreciate the help. I see 2 mounting holes on the valence. This is not a replacement bumper, just a lower valence air dam. Kinda confused now. |
| AZ914 |
Aug 10 2016, 06:53 AM
914 Dumbass ![]() ![]() ![]() Group: Members Posts: 1,469 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region |
You can either just peel back the rubber: it is attached by a channel that runs the length of the hood/headlights, and two tabs on both sides (vertically). Oh, and remove the plate and mount. Not sure what else is involved in doing this. Can't remember if those titties need to come off somehow.
Another option is to just take off the whole thing: If I remember correctly, there are two 19mm bolts accessed from beneath the bumper. Unbolt those, the pull the bumper away from the car. However, you will effectively be 'peeling back the rubber' the same way on the top/sides. I had put on a similar GT bumper when I had my BUBS. I remember that the mount holes were different than the original valance so I did have to drill into the body. |
| ndfrigi |
Aug 10 2016, 08:05 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,977 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California
| maf914 |
Aug 10 2016, 08:45 AM
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None
Ndfrigi's photos are a big help. When you unbolt the two bolts from the two bumper shocks you then have to release the rubber bumper cover ends from the channels on the sides before you can pull the bumper off. You sort of "peel" the sides away. When reinstalling the bumper you must work the bumper cover ends back into these channels. Somewhat of a PIA.
| sfrenck |
Aug 10 2016, 10:45 AM
Member ![]() ![]() Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region
Take some measurements before you go too far to make sure the dam is wide enough... I had a fiberglass one that was about an inch too short (thread on here a bit ago by someone else with the same issue).
Ended up getting a new dam from Mikey914 - fit perfectly. |
| TheCabinetmaker |
Aug 10 2016, 01:51 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,367 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Jeez. You don't peel anything. Undo the bolts that insert toward the top, under the bottom of the rubber cover (inside the two holes). Push the rubber towards the rear of the car. The flanges will then release the rubber cover on the ends.
| carcus |
Aug 10 2016, 10:24 PM
Thank you guys for all the info and pics. I now know what I have to do. I love this message board. You are all so helpfull and have an appreciation for keeping the cars we grew up with on the road. Doing a cab carpet install soon with the OEM material.
Lo-Fi Version | Time is now: 11th March 2026 - 07:42 AM |
