EdwardBlume |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California ![]() ![]() |
See pict. Is this an early light or another model? Inside the housing it says Hella. On the outside "made in Germany"
Attached thumbnail(s) ![]() ![]() |
Tom_T |
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California ![]() ![]() |
Rob,
If it says Germany, then it's post reunification & so late production by Hella, as in 70-76 & up to reunification it would say West or Western Germany instead. I'm not sure of the exact date that Hella would've changed the molds for the lens post actual reunification, but it's probably no older than the early 90's or late 80's. It's still correct OEM replacement part, .... PSS - which you can still get from Porsche today, since it also goes into 911/912 which they support well. PS - it should have the rectangular black rubber gasket that fits around the raised lense & held under the 2 screws. (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
dlkawashima |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,749 Joined: 1-October 10 From: San Jose Member No.: 12,234 Region Association: Northern California ![]() |
Rob, If it says Germany, then it's post reunification & so late production by Hella, as in 70-76 & up to reunification it would say West or Western Germany instead. I'm not sure of the exact date that Hella would've changed the molds for the lens post actual reunification, but it's probably no older than the early 90's or late 80's. It's still correct OEM replacement part, .... PSS - which you can still get from Porsche today, since it also goes into 911/912 which they support well. PS - it should have the rectangular black rubber gasket that fits around the raised lense & held under the 2 screws. (IMG:style_emoticons/default/beerchug.gif) Tom /////// All original Hella dome lights say "Made in Germany" as can be seen in the image below. Can't say for certain but I'd imagine the trunk lights would be the same. (IMG:http://www.914world.com/bbs2/uploads/post-12234-1455014085.jpg) |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,204 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
914 trunk lights are the same as the 64-73 911 plate lights. Light should have dome center.
dlkawashima |
Lo-Fi Version | Time is now: 31st July 2025 - 11:27 AM |
