| matthepcat |
Aug 11 2016, 01:00 PM
Meat Popsicle ![]() ![]() ![]() Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
| iwanta914-6 |
Aug 11 2016, 01:10 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 718 Joined: 26-June 09 From: Minnesota Member No.: 10,510 Region Association: None
| Andyrew |
Aug 11 2016, 01:39 PM
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,381 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California
Biggest issue I see is he is running the stock fuel injection.
| krazykonrad |
Aug 11 2016, 01:49 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,182 Joined: 21-February 06 From: Canton, GA Member No.: 5,610 |
| HAM Inc |
Aug 11 2016, 03:03 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 850 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
Not trolling, just sharing info. (IMG:style_emoticons/default/smile.gif) I've prepped plenty of T4 heads for turbo engines. The heads aren't well suited for it, but with a small bore and low revs they can be made to work for a while. T4 heads are inherantly weak in the ex port area and as a result are extremely vulenerable to elevated EGT's, which all turbo engines are prone to. This is why small bores work better than big bores, as the bigger the bore, the weaker the head. Thermal coatings are a must! |
| Mueller |
Aug 11 2016, 04:32 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,157 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
| matthepcat |
Aug 11 2016, 06:31 PM
I know the guy that owns this car. Sold him the wheel adapters off my 914V8 7 years ago. It used to have a nice blue paint job on it. Certainly a stalled project.
| 2mAn |
Aug 11 2016, 06:43 PM
trying to see how long I can go without a 914 ![]() ![]() ![]() Group: Members Posts: 502 Joined: 14-November 13 From: Westchester (Los Angeles) Member No.: 16,644 Region Association: Southern California |
He might get more hits if he removes the wing and that decal in the back window. ...and the wheels, and the ruined "paintjob" and.... I know the guy that owns this car. Sold him the wheel adapters off my 914V8 7 years ago. It used to have a nice blue paint job on it. Certainly a stalled project. ambitions were quite high on this project all that said, it would be cool to see this finished |
| Mike Bellis |
Aug 11 2016, 07:17 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
it's a '76 and will never pass a smog test... (IMG:style_emoticons/default/sad.gif)
| JeffBowlsby |
Aug 11 2016, 08:45 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,388 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
Seems to me that when Jeff Shyu was doing his, he used a rising rate fuel pressure regulator.
He also was playing with the reference air pressures of the MPS to get it to work with the turbo. In stock configuration the MPS references intake manifold pressure and ambient air pressure on either side of the diaphragm. For the turbo set-up Brad Anders suggested to him to use intake manifold pressure and some other condition...I want to say it was to close up the two ambient air vent ports for more of an absolute pressure reference, but I could easily be wrong and that does nto sound right. I don't understand how the correct pulse width could be attained using an MPC based system. |
| Dave_Darling |
Aug 12 2016, 09:46 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,367 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Not trolling, just sharing info. (IMG:style_emoticons/default/smile.gif) That's an old inside joke. "Everybody knows you can't turbo a 914!" Seems to me that when Jeff Shyu was doing his, he used a rising rate fuel pressure regulator. ... I don't understand how the correct pulse width could be attained using an MPC based system. If the fuel pressure is right, you don't really need the correct pulse width. But fuel pressure is a pretty coarse adjustment, I think... --DD |
| Andyrew |
Aug 12 2016, 11:10 AM
Seems to me that when Jeff Shyu was doing his, he used a rising rate fuel pressure regulator. ... I don't understand how the correct pulse width could be attained using an MPC based system. If the fuel pressure is right, you don't really need the correct pulse width. But fuel pressure is a pretty coarse adjustment, I think... --DD I agree. Granted people have been doing it on Honda's and other 4 cyls for years. They generally all blow up though.. Its not a long term solution. I think the only real solution is a standalone system like Megasquirt. Being able to adjust the timing will really help low end torque and the ability to run lower boost for a higher power gain. |
| Brian Mifsud |
Aug 12 2016, 11:31 AM
Mechanical Engineer ![]() ![]() ![]() Group: Members Posts: 981 Joined: 3-March 03 From: Penngrove, CA Member No.: 384 Region Association: None |
Smogging a '76 with NO mods is trouble enough.. |
| Cracker |
Aug 12 2016, 02:44 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States
run (away)
| Bulldog9 |
Aug 13 2016, 09:59 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 706 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region |
I'm finding this tempting...... $3500?
| Mueller |
Aug 13 2016, 10:30 AM
No intercooler that I can see, that it going to be some hot air going into that motor for sure!
Hopefully the buyer knows CA smog laws and he doesn't sell it to someone as-is and new owner gets surprised when the DMV asks for the smog cert which will not exist. Unless a super clean rust free chassis I don't see it being worth that much. |
Lo-Fi Version | Time is now: 14th November 2026 - 02:32 PM |
