Suby tranny adaptor for type IV motor now available |
Jon H. |
Aug 16 2016, 06:07 AM
Member Group: Members Posts: 237 Joined: 1-July 11 From: Ottawa, Canada Member No.: 13,264 Region Association: Canada |
I'm not sure if this was posted already but in case it wasn't.
http://www.subarugears.com/Adaptors/Adaptors.html (IMG:http://www.914world.com/bbs2/uploads_offsite/www.subarugears.com-13264-1471349248.1.jpg) The swap would be pricey but it would be sweet! I've swapped a Suby tranny into my vanagon and its night and day. Regards' Jon |
jim_hoyland |
Aug 16 2016, 06:15 AM
Get that VIN ? Group: Members Posts: 9,319 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Is this a better fit for 914's with Sudy motors ? or an upgrade for a type IV ?
mepstein |
Aug 16 2016, 06:19 AM
914-6 GT in waiting Group: Members Posts: 19,315 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Or a Suby trans on the back of a Porsche 6?
Mark Henry |
Aug 16 2016, 06:27 AM
For different motors to the subi trans, if you go to the site there are several motors that can be adapted.
For a Bug, bus or maybe a 911 they sell gears to reverse the trans for rear engine. |
Jon H. |
Aug 16 2016, 07:19 AM
It's so you can use the type IV motor with a Suby tranny. I'm not sure about the six motor? The adaptor plate will work but I'm not sure about the flywheel? Can a typeIV fly wheel be used on a six? Its a great company with awesome customer service!
Jon h. |
Chris H. |
Aug 16 2016, 08:11 AM
Senior Member Group: Members Posts: 4,032 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Not sure how it works in this configuration but on Subaru swaps the flywheel for the trans is what you use regardless of the Subaru engine fitted. My EG33 has a 2006 WRX flywheel bolted to it. I have no idea if this is relevant to the kit but that looks like a lightened Subaru flywheel in the pic.
The 5MT is a good trans as long as you find one that has not been beaten to hell by a youngster (or oldster ) who has done 4WD neutral drops or missed shifts at 7krpm. All you care about is the trans, the center diff is not important since you take that out. As long as it's good you get very smooth, short shifts. For highway cruising you want the higher gear ratio. I think 3.90 which came in most cars (outback, forester). Cheaper too. Mine is 3.7. The .2 does make a difference (IMG:style_emoticons/default/biggrin.gif) . |
Jon H. |
Aug 16 2016, 11:51 AM
Your right about swapping suby trannys and motors around, you can use any suby flywheel but with this set up you will need the custom flywheel with the adaptor plate. The adaptor plate will add some distance between the engine and transmission. Also with this set up you will also be using a suby starter which will have different tooth pitch.
I agree with the gearing, I'm running 3.93's in my westy. Regards' Jon h |
Lo-Fi Version | Time is now: 10th June 2024 - 03:54 AM |
