How to hook up a ignition coil with points |
tornik550 |
Aug 19 2016, 08:47 AM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I have a 2.7 /6 and I have never used points. I have always had some sort of electronic ignition. I have a new set of point and would like to install it. How do I do it? I know how to set the gap and dwell. What wires do I hook to the black wire coming from the points?
I know this is a super simple question, I just have no experience here. |
stugray |
Aug 19 2016, 09:36 AM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Ignition +12VDC (from the key) goes to Coil + (POS).
Coil - (NEG) goes to the points (usually the green wire). Coil - (NEG) is also where the TACH wire goes (purple black?) |
ClayPerrine |
Aug 19 2016, 11:35 AM
Life's been good to me so far..... Group: Admin Posts: 15,474 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
It's a little different with a six, as they use CD ignition, with the points providing a low voltage trigger signal.
The points should be hooked to the black wire coming out of the harness. No condenser. Just the points. I would suggest that you look into a pertronics for the early 911. It will fit your distributor, and it will last forever, unlike points. |
Mark Henry |
Aug 19 2016, 11:44 AM
You really should run a high output CD box, whether the factory CDI or MSD, mallory Hi-fire, etc.
The six with it's higher domed, often higher CR pistons really needs help in the fire department. |
Lo-Fi Version | Time is now: 22nd May 2024 - 09:32 PM |
