Parking Brake Replacement |
Tburt52359 |
Aug 20 2016, 04:13 PM
Newbie Group: Members Posts: 49 Joined: 24-May 15 From: Orange County Member No.: 18,756 Region Association: Southern California |
Hello. I am attempting to replace parking brake. Question- how do you remove the piece on the brake that attaches to the cable. It appears it is a rivet. I thought it would be some type of bolt. There is always a curve ball thrown in. Thx.
Attached thumbnail(s) |
ejm |
Aug 20 2016, 06:47 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,693 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
It's just a pin that is seized in the eye on the cable. There was a clip to keep it in place. you can see the groove for it in the second pic. If you can pull the pin on the spreader piece at the other end of the cable you should be able to remove the handle with the cable so you can heat and soak the pin to loosen and remove it.
Tburt52359 |
Aug 20 2016, 07:06 PM
It's just a pin that is seized in the eye on the cable. There was a clip to keep it in place. you can see the groove for it in the second pic. If you can pull the pin on the spreader piece at the other end of the cable you should be able to remove the handle with the cable so you can heat and soak the pin to loosen and remove it. Emj, would the pin be where the left and right cables meet? Thanks for your assistance! |
whitetwinturbo |
Aug 20 2016, 07:42 PM
Honey, does this wing make my ass look fat? Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California |
This is the frozen/rusted pin ......... PB blaster and then gently sand and then find "keeper" that secures it ....
Tburt52359 |
Aug 20 2016, 08:28 PM
Thank you
Lo-Fi Version | Time is now: 6th June 2024 - 11:12 PM |
