OT 911 question, Alternator |
r_towle |
Aug 20 2016, 09:33 PM
Custom Member Group: Members Posts: 24,579 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Sorry to post this here, but many of you own 911,s also.
So my 1984 is charging at 12 Vdc. How hard is it to remove the alternator whole motor is in the car, 3.2 Is the regulator part of the alternator? Do I need special tools to get it out? I will bring it to my favorite place and have them rebuild it. Rich |
injunmort |
Aug 20 2016, 09:58 PM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
i helped a friend do his on 1988 2 years ago. removing the alternator was pretty straight forward, no special tools. if i remember correctly, the regulator is part of the alternator.
amfab |
Aug 20 2016, 10:06 PM
Member Group: Members Posts: 393 Joined: 17-May 16 From: Los Angeles Member No.: 20,004 Region Association: None |
If I remember correctly from my 84, the regulator is part of the alternator.
I started to write up how to do this from memory, but: http://forums.pelicanparts.com/porsche-911...emoval-car.html ...is probably a better resource. Special tools:definitely a magnetic pickup tool for this one |
porschetub |
Aug 20 2016, 10:49 PM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
HHHHmmmmm,now that looks easy,in a 914????
flyer86d |
Aug 21 2016, 06:41 AM
Member Group: Members Posts: 425 Joined: 12-January 11 From: Corea, Maine Member No.: 12,585 Region Association: North East States |
Yes it has an internal regulator and can be changed without removing the engine. I did the one on my 1983 Targa years back in a shopping center parking lot with the factory tool kit. It probably is a Paris-Rhone alternator if it is the original which is pricey but there is an identical aftermarket replacement at half the price.
You have to unbolt the strap, remove the small bolts that attach the fan housing to the engine shroud, pull the fan and housing out as a unit far enough to unbolt the wires to the alternator and take out the whole lot. Carefully pop off the fan, unbolt the alternator from the housing. As the manual says, installation is simply the reverse of the removal! Charlie |
mepstein |
Aug 21 2016, 06:54 AM
914-6 GT in waiting Group: Members Posts: 19,282 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Yes it has an internal regulator and can be changed without removing the engine. I did the one on my 1983 Targa years back in a shopping center parking lot with the factory tool kit. It probably is a Paris-Rhone alternator if it is the original which is pricey but there is an identical aftermarket replacement at half the price. You have to unbolt the strap, remove the small bolts that attach the fan housing to the engine shroud, pull the fan and housing out as a unit far enough to unbolt the wires to the alternator and take out the whole lot. Carefully pop off the fan, unbolt the alternator from the housing. As the manual says, installation is simply the reverse of the removal! Charlie (IMG:style_emoticons/default/agree.gif) have it rebuilt $100-120 Check the mag fan housing for cracks. If it's cracked, or the fan is damaged, send it to Ben/ MB911 for repair. |
PanelBilly |
Aug 21 2016, 09:19 AM
914 Guru Group: Members Posts: 5,808 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Be careful with that fan. They are expensive to repair. Also, don't loose the spacer washers on the nut that holds the belt on. By the way if the regulator was external, you'd see it in the engine compartment
larryM |
Aug 21 2016, 12:05 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
also worth looking at this thread http://forums.pelicanparts.com/porsche-911...ternatives.html i had an 89 3.2 alternator that was "frozen" in the housing (FLA salt-air car) - so the shop rebuilt it inside the housing - i have a spare '88 fan/alt/hsg just in case . |
Drums66 |
Aug 21 2016, 12:28 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
.......Internal regulator(alternator)
(IMG:style_emoticons/default/bye1.gif) |
Lo-Fi Version | Time is now: 23rd May 2024 - 08:42 AM |
