Grommet research, Is this a throttle cable grommet? |
brant |
Aug 22 2016, 10:36 AM
914 Wizard Group: Members Posts: 11,632 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I'm trying to find grommets for another application
The open one is a good feeling t but I'm trying to use it as a plug in my engine shroud where stock 911 mfi injectors go. So ideally looking for a plug without a hole I can't read the part numbers in this spare parts bin grommet next to it I think it might be a 4cylinder accelerator grommet Is that what it is? Anyone know where I can buy 6 of them? Attached thumbnail(s) |
TheCabinetmaker |
Aug 22 2016, 10:56 AM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I've seen a couple of those on fours. One on the engine shelf for oil temp wire and one on the rear vertical tin for the starter harness.
TheCabinetmaker |
Aug 22 2016, 11:29 AM
914Sixer |
Aug 22 2016, 11:56 AM
914 Guru Group: Members Posts: 8,900 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Going to be a VW part number . Look at Bus engine tin rubber.
rhodyguy |
Aug 22 2016, 11:57 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,085 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Blind grommet looks like the ticket.
Mikey914 |
Aug 22 2016, 01:33 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Letme know if you can't find em.
TheCabinetmaker |
Aug 22 2016, 02:40 PM
You should make every grommet on the car mark. (IMG:style_emoticons/default/wink.gif)
brant |
Aug 22 2016, 03:44 PM
you guys are amazing..
the blind grommet looks like that is it! Mark, I can send you a PM, but I didn't see that grommet on your site? it looks like the clark rubber ones come in 32mm or 38mm unfortunately I need a 36mm (could probably get by with a 35mm) Mark, what do you have in mind? anything close to 36mm? brant |
TheCabinetmaker |
Aug 22 2016, 04:07 PM
Google metric blind rubber grommets. Lots of hits.
brant |
Aug 22 2016, 05:41 PM
I found a few. Australia. Great British . And Chinese
I'm be got a Chinese sample coming to see Fingers crossed |
rhodyguy |
Aug 22 2016, 06:23 PM
Does it have to be metric? 1.41". Do they have one for a 1 1/2" hole?
914Sixer |
Aug 22 2016, 07:07 PM
VW 021 119 569A German Supply has them for $5.83
Lo-Fi Version | Time is now: 3rd June 2024 - 12:39 AM |
