wanted to borrow for testing purpose:, a 75 2.0 d-jet FI harness |
DRPHIL914 |
Aug 24 2016, 06:44 AM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I have a replacement harness that seems to have developed a short at one of the injector connectors- trying to get it all sorted out before we leave for Okteenerfest in a month and this is really bugging me! I am hoping to for sure rule it out/in by trying a known good FI harness in place of mine -
thanks - Phil |
JeffBowlsby |
Aug 24 2016, 09:19 AM
914 Wiring Harnesses Group: Members Posts: 8,524 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Hi Phil, Those female contacts on the harness can loosen up over time, especially if they are wiggled around. Its very easy to remove them from their housing and tighten up their grip with a set of pliers.
Attached image(s) |
DRPHIL914 |
Aug 29 2016, 10:02 AM
jeff
Thanks for the information, I took your advice and I did this with the one I suspected and I think that issue was eliminated, however im still getting a buck above 4000 rpm and an intermittent change in the A/f reading that feels like slight hesitation. - I replaced the fuel pump yesterday as it was really making a lot of noise and I think it may have beenon its last leg - new one very quiet, fuel pressure steady and car ran and idle steady last night. I hope to do a better test drive tonight. - the only other thing I can think of would be the CHT connection is not perfect, or the MPS is going- it holds vac but could it be failing? yesterday earlier vefore changing the pump I had a hesitation and the A/F meter went much more rich , like a 9.0 whereas with the previous connection issue on the injector it would do the opposite. - I will be sending 2 MPS your way for eval- if you have one , a043 for a '75, 2.0 I would take it! |
Lo-Fi Version | Time is now: 1st June 2024 - 07:14 AM |
