Tastyplacement |
Newbie ![]() Group: Members Posts: 39 Joined: 31-August 16 From: Austin, TX Member No.: 20,358 Region Association: MidAtlantic Region ![]() |
I have a Porsche 550 replica with a 914 side-shift setup. Sloppy shifting is my woe.
I got a new ball cup bushing to insert into the shift rod coupler/head. The pelican parts tutorial states that it is really tough to get the bushing in there. My new bushing, though, is so loose that it falls out, it's definitely swimming in the shift rod coupler. Is this normal, or is the shift rod coupler worn out? |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
The coupling should snap onto the ball and require significant force to remove.
But the cup bushing is supposed to move freely inside the cup. In fact you need to grease it so that it can slide in & out. |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,735 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
(IMG:style_emoticons/default/agree.gif) and (IMG:style_emoticons/default/welcome.png) . What part of Austin? That's my old home town! My 1st 914 ride was in 71 on a rainy nite. My Buddy scared the ever loving baJesus out of me. I'd never been in anything sportier than a Chevelle at the time. (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/av-943.gif) We have about 4 other members in Austin. (IMG:style_emoticons/default/beerchug.gif)
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
What is your firewall bushing setup?
That is where most of the slop can be removed. There are also some good cable shifters that might be your ultimate solution. |
Tastyplacement |
thank you sir...
Tastyplacement |
(IMG:style_emoticons/default/agree.gif) and (IMG:style_emoticons/default/welcome.png) . What part of Austin? That's my old home town! My 1st 914 ride was in 71 on a rainy nite. My Buddy scared the ever loving baJesus out of me. I'd never been in anything sportier than a Chevelle at the time. (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/av-943.gif) We have about 4 other members in Austin. (IMG:style_emoticons/default/beerchug.gif) I am in Circle C, and I am a Harris Hill member. As for my firewall bushing--this is a 550 replica, so the firewall is just a hole, and the shift rod passes through one of those heim connectors bolted to the center tunnel (can't seem to post image here)... |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,023 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Where did you buy the bushing and who makes it?
mark04usa |
'70 1.7 Tangerine ![]() ![]() Group: Members Posts: 355 Joined: 14-September 09 From: Austin TX Member No.: 10,805 Region Association: Southwest Region ![]() ![]() |
(IMG:style_emoticons/default/welcome.png) I'm in South Austin as well. Please do share some photos of your car.
The shifter should work well with enough support and some tight bushings. (IMG:style_emoticons/default/beerchug.gif) |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
Just curious on the manufacturer of the cup I have some, if it's shot PM me. |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,873 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Mine was tight ,bought it a long time ago from Pelican.
Your shift rod in the 550 would be fairly short I'am thinking but if you get the right (tight ) ball cup you will still need some sort of intermediate support for the shift rod,I really think the one from Chris @ Tangerine Racing would work for you . |
stugray |
If you are talking about this cylindrical bushing, that snaps on the end of the ball then slides into the shift coupling:
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.pelicanparts.com-10819-1472709720.1.JPG) It is supposed to slide in and out as you shift. It should not be so 'tight' that it does not move. |
Mikey914 |
Basically the grease fills the gap so that it will not move too much laterally.
Tastyplacement |
Wow, what a great forum community.
The bushing came from QE auto parts and was at least advertised as original porsche. If this is supposed to move within the rod head, it's probably the right thing. As for the bushing at the firewall, it is substituted with the following heim joint, and this joint is nice and tight and solid. (IMG:http://www.914world.com/bbs2/uploads_offsite/lh3.googleusercontent.com-20358-1472740465.1.jpg) This photo leads to another question--I had a super high-quality Lovejoy u-joint machined to accept 2 set screws, pictured. But the shafts are smooth bore, and although the u-joint fits snugly, I am wondering if I need some indent on the shafts. This is also, unfortunately, the adjustment point for the length and rotation of the shaft. Ideas? |
Tastyplacement |
(IMG:style_emoticons/default/welcome.png) I'm in South Austin as well. Please do share some photos of your car. The shifter should work well with enough support and some tight bushings. (IMG:style_emoticons/default/beerchug.gif) Pics of Car... (IMG:http://www.914world.com/bbs2/uploads_offsite/lh3.googleusercontent.com-20358-1472745127.1.jpg) Type IV power and 901 Transmission (in younger days, it's a bit more faded now): (IMG:http://www.914world.com/bbs2/uploads_offsite/lh3.googleusercontent.com-20358-1472745128.2.jpg) |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,248 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
Dimple the rod so the tapered end of the set screw seats in the rod. Jwest (member vendor) offers a cheap solution to the one time use tapered screw. Bolt with a tapered end and a jam nut.
Beautiful car. Must scoot with the t-4 and the HP to weight ratio. |
maf914 |
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None ![]() ![]() |
Very nice 550! (IMG:style_emoticons/default/first.gif)
What manufacturer makes this particular car? Any more photos of the mechanicals? (IMG:style_emoticons/default/idea.gif) |
Shadowfax |
Show us the meaning of haste ![]() ![]() ![]() Group: Members Posts: 509 Joined: 19-January 15 Member No.: 18,340 Region Association: South East States ![]() ![]() |
Sweet. Could be a Beck?
Tastyplacement |
stinkindiesel |
Member ![]() ![]() Group: Members Posts: 184 Joined: 14-June 13 From: Georgetown, TX Member No.: 16,012 Region Association: Southwest Region ![]() |
Welcome from another semi Austinite. I live up in Georgetown, but work in south Austin. Yes, I do spend almost 3 hours a day in the car. That's what books on MP3 are for.
Purty looking 550! Gary |
r_towle |
Hard to tell but if you are still experiencing too much play start close to the shifter, even a small amount of play near the shifter amplifies the issue
Lo-Fi Version | Time is now: 4th July 2025 - 12:21 PM |
