Original Fitting leak |
xsurfer |
Sep 11 2016, 10:10 AM
Member Group: Members Posts: 279 Joined: 4-April 06 From: La Canada, CA Member No.: 5,818 |
I have a 71 factory six 88k miles.
I have an oil leak in the union between the hard line union at the lower oil tank line. I'm trying to retain the original aluminum fittings that have the date on them. Is there a better way than not to stop the leak without replacing the lines? Thanks for your thoughts! Gene |
smg914 |
Sep 13 2016, 05:39 PM
Sahara Beige Steve Group: Members Posts: 1,962 Joined: 22-February 04 From: Tampa, FL Member No.: 1,695 Region Association: None |
If its leaking where the two lines meet, then I would think they aren't seated properly. Unless there is some damage to one or both of the fittings.
xsurfer |
Sep 15 2016, 09:17 AM
It is the union that is leaking. It was so tight when I got the car extensions had
to be put on the wrenches. Even then I had to have a younger friend break it loose. If its leaking where the two lines meet, then I would think they aren't seated properly. Unless there is some damage to one or both of the fittings. |
xsurfer |
Sep 15 2016, 09:38 AM
Lo-Fi Version | Time is now: 1st June 2024 - 11:28 PM |
