> Oilfilter does not fit, See pics
Frankvw
post Sep 11 2016, 10:10 AM
working on my first 914 !
Region Association: Europe
Hi all. I started working on my 914 and first thing was an oilchange and a new filter. Got all the parts new, and started working. How hard is an oilchange right?
All went fine untill I removed the old oilfilter...i thought a wrong one was there since it was another type then should be there, it was smaller in diameter.
However... The new filter does not fit. It is too wide since it hits another part, a supportthing that hold a wheel that presses on the belt.
See pics.
The new bosch filter is hitting this supportbracket.
This is the new filter i think is ok
This filter came off. It is smaller in diameter and clears the supportbracket
Can you please advice? Can i get that smaller diameter oilfilter to continue ?
Replies(1 - 15)
bretth
post Sep 11 2016, 10:26 AM
Is that little wheel a belt tensioner for an AC system? Never seen before.
Brett
RAX914
post Sep 11 2016, 10:30 AM
This is the Bosch oil filter I just used:
Frankvw
post Sep 11 2016, 10:41 AM
Sorry...it is a 1973 1.7 (forgot to mention that)
Yes...it is a tensioner for the ac belt, so it seems.
And that bosch filter is too wide. The filter that was on it does fit, but I checked the crossreference site for that filter and the needed filters do not seem to be the same.
http://www.oilfilter-crossreference.com/co...PROMOTIVE/PH195
The filter that rax914 is mentioning is compatible with what came off....is that Ok for a 914 ?
RAX914
post Sep 11 2016, 10:53 AM
I have a '72 1.7 and the Bosch 3402 fits well, but I don't have air conditioning. Here are the product specs for the 3402:
Mueller
914 Freak!
Just buy another smaller diameter filter, it obviously worked since the motor has not blown up.
There are at least 5 cross ref numbers on the old filter.
Mueller
post Sep 11 2016, 10:54 AM
914 Freak!
QUOTE(RAX 914 @ Sep 11 2016, 09:53 AM) *
Those dimensions would be for a square filter! (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/biggrin.gif)
Frankvw
post Sep 11 2016, 11:08 AM
Mueller, "it obviously worked since the motor has not blown up. "
That is true, but I also do not re-use the flat copper washer that was present under the drainbolt instead of the crushable ring that should be there although it did not blow up the motor too :-)
I thought all filters have their own specs and flow etc , so since it is other then the book states I just wanted to check with the 914 community what to use now. Maybe the previous oilchnage just got a fitting filter, but maybe not a correct one...
Dion
post Sep 11 2016, 12:27 PM
RN
I use MAHLE OC-28.
I usually had probs with the length of canister with my aftermarket
BAT external oil cooler adaptor. The Mahle works best in that regard. Not sure though of clearance with the a/c pulley and diameter of canister. Maybe give it a go . Good luck.
tomeric914
post Sep 11 2016, 01:28 PM
One Lap of America in a 914!
Baldwin B228 is my favorite. Same length as the stock filter but smaller in diameter. Great when using a sandwich adapter for an external cooler or when you're sick of busting your knuckles dealing with the stock size filter.
http://catalog.baldwinfilter.com/PartSpeci...partnumber=B228
TheCabinetmaker
post Sep 11 2016, 02:05 PM
I drive my car everyday
QUOTE(tomeric914 @ Sep 11 2016, 02:28 PM) *
(IMG:style_emoticons/default/agree.gif) A 944 filter fits too.
tomeric914
post Sep 11 2016, 03:36 PM
Yes, that's a Baldwin B178 which hangs a bit too low on the 914 in my opinion. Same as Rabbit, Jetta, Golf, etc.
http://catalog.baldwinfilter.com/PartSpeci...partnumber=B178
QUOTE(The Cabinetmaker @ Sep 11 2016, 04:05 PM) *
Dave_Darling
post Sep 11 2016, 06:01 PM
914 Idiot
I would be tempted to get rid of the tensioner. Then again, I don't really like the AC setups on most of our cars.
--DD
Big Len
post Sep 11 2016, 06:34 PM
I have used the K & N and Mobil 1 filters in addition to the Mahle.
JOEPROPER
post Sep 11 2016, 07:21 PM
The answer is "no" unless you ask...
I would just get another ph195 and call it a day.
Frankvw
post Sep 14 2016, 01:02 PM
Ok...since a PH195 was not available in NL, I bought a MANN filter, which is compatible. It has a 'better' diameter for me, but is about an inch longer than teh PH195 that came off the engine.
I fits nice and does not stick out, is nicely tucked away even though it is a bit longer
as you can see the one recommended is shorter and has a bigger diameter, the other MANN filter is longer and has a smaller diameter.
A small job, but one down from the list ! Thanks for the tips and advice !
- Lo-Fi Version Time is now: 4th November 2026 - 01:27 PM
