Six oil tank suction line (the short one), can you remove the tank with this still fitted? |
porschetub |
Sep 13 2016, 06:44 PM
Advanced Member Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
As per thread ,reason I ask is I can't see a way to tighten the fitting on the hose in situ,my idea was to remove the tank tighten the fitting and reinstall.keen to know,thanks oh wise ones (IMG:style_emoticons/default/biggrin.gif) and (IMG:style_emoticons/default/beer.gif)
Oh by the way getting closer to getting it running.... |
gereed75 |
Sep 13 2016, 07:04 PM
Senior Member Group: Members Posts: 1,261 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
Yep, it has to be at just the right angle. Slightly angled toward the engine as I recall
brant |
Sep 13 2016, 07:11 PM
914 Wizard Group: Members Posts: 11,641 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
you picked up on it..
its necessary to tighten it prior to install |
Krieger |
Sep 13 2016, 11:45 PM
Advanced Member Group: Members Posts: 4,731 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Take a Sharpie and mark the correct orientation of the line relative to the tank before you take the tank out.
porschetub |
Sep 14 2016, 02:25 PM
Take a Sharpie and mark the correct orientation of the line relative to the tank before you take the tank out. Thanks to all ,have made up a few basic tools to tighten outer fittings and they worked fine. Have all pipes /hoses test fitted and lined up with support @ the engine case and trailing arm mount,my plan is the drill the male/male connector on the suction to make oil changes easier and cleaner. Really want to check the tank @ the same time PO said he had it repaired many years ago but never told me if it was clean. |
Lo-Fi Version | Time is now: 17th June 2024 - 10:01 AM |
