This site is not affiliated with Porsche in any way. Its only purpose is to provide an online forum for car enthusiasts. All other trademarks are property of their respective owners.  |
| amfab |
			  Sep 14 2016, 08:58 AM
        		 Member ![]() ![]() Group: Members Posts: 401 Joined: 17-May 16 From: Los Angeles Member No.: 20,004 Region Association: None
			 Hi,
			I am looking to buy some used 3" spacing 911 struts but I want the late wedge-pin style ball joint bolts. The struts I am looking to buy are: Boge 1-0211-32-173-0 Porsche part # 911-341-080-02 I cannot find that Porsche part number. I am concerned that they are the early style and the PET only shows the later part number. The seller sent me these picts of the bottom of the struts. Can anyone identify early or late from the picts? -Andrew Attached thumbnail(s)  |
| gms |
			  Sep 14 2016, 10:54 PM
        		 Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,737 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest
			 The picture you show is a 1969 or later strut, the early struts look totally different and will not attach to a post 1969 a-arm (see below)
| jcd914 |
			  Sep 14 2016, 11:03 PM
        		 Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,096 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California  |
			 If by "early or late" you want  to know if they are early (69 to 72)  pinch style or late (73 to 89) taper pin style, those are late taper pin struts.
		Black paint would infer they are Boge struts but they could be repainted. Jim  |
| 914Sixer |
			  Sep 15 2016, 06:25 AM
        		 914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,308 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
			 Mid 911 struts are split at the base and use a pinch bolt.  Late 911 are solid base and use v shaped wedgepin.  Since there is no split at the base, the struts are late style and use the same ball joint as the 914.
| pencap914 |
			  Jan 23 2021, 11:26 AM
        		 Member ![]() ![]() Group: Members Posts: 79 Joined: 16-April 06 Member No.: 5,872 Region Association: Northern California  |
			 I too am searching for a pair of struts with 3" spacing and later "wedge pin" style.
			I came across these from a seller, but it looks like these are the pinch bolt...right? Attached thumbnail(s)  |
| Montreal914 |
			  Jan 23 2021, 12:10 PM
        		 Senior Member ![]() ![]() ![]() Group: Members Posts: 1,954 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California
			 ^^^ Yes, these are the pinch style.
		Below is a pin style, disregard the green paint, I had mine refreshed and wanted them green (IMG:style_emoticons/default/biggrin.gif) . Good luck with your search (IMG:style_emoticons/default/smile.gif)  |
| JeffBowlsby |
			  Jan 23 2021, 12:37 PM
        		 914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,105 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
			 You may be looking for these.  Wedge bolts, 3 in caliper spacing.  Straight arms, they fit Bilstein dampers.
			I would consider offers for the set, PM if interested. Can include new wedge bolts/roll pins. Attached thumbnail(s)  |
| mepstein |
			  Jan 23 2021, 03:13 PM
        		 914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,200 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
| pencap914 |
			  Jan 25 2021, 03:10 AM
			 ^^^ Yes, these are the pinch style. Below is a pin style, disregard the green paint, I had mine refreshed and wanted them green (IMG:style_emoticons/default/biggrin.gif) . Good luck with your search (IMG:style_emoticons/default/smile.gif) Thanks for clarifying this! looking good. (IMG:style_emoticons/default/biggrin.gif)  |
		Lo-Fi Version | Time is now: 4th November 2025 - 12:40 AM |
		914World.com is the fastest growing online 914 community! We have it all, classifieds, events, forums, vendors, parts, autocross, racing, technical articles, events calendar, newsletter, restoration, gallery, archives, history and more for your Porsche 914 ...  |
