Oilfiller Neck question, why is there a cap ? |
Frankvw |
Sep 14 2016, 01:06 PM
working on my first 914 ! Group: Members Posts: 652 Joined: 13-April 16 From: Holland, the Netherlands Member No.: 19,896 Region Association: Europe |
Hi, since I was working to tidy up the engine a bit, check the vacuumhoses, change oil etc, I removed the oilfiller neck, since it is about the dirtiest part in the bay and wanted to clean it.
When I looked in the case with a flashlight to see what it looked like in there, I saw a small plastic cap laying in there. It does fit in the oilfillerneck base bottom, see pic, so I guess that is where it belongs. I took out the Haynes manual but I cannot find this part mentioned. What is it for ? Why is there a capped hole in there ? |
mark04usa |
Sep 14 2016, 01:39 PM
'70 1.7 Tangerine Group: Members Posts: 351 Joined: 14-September 09 From: Austin TX Member No.: 10,805 Region Association: Southwest Region |
Looks like stopper for the breather valve, part # 022 115 486. #9 in diagram
Frankvw |
Sep 14 2016, 01:44 PM
Looks like stopper for the breather valve, part # 022 115 486. #9 in diagram Great, that is the one. Thanks ! I will have to check if nothing is missing there... I cannot find it in the Haynes, where did that diagram come from ? From the partnumber you mentioned I found post http://www.914world.com/bbs2/index.php?showtopic=19995 so it happens to others as well :-) What does the valve in there do ? regulation of crankcase pressure ? |
Frankvw |
Sep 15 2016, 12:49 PM
Ok, checked all in the diagram and all is there.
So I cleaned it up, all back together, install new gasket and the plug in. Small job, always nice to have some result and another thing off the to-do list. oh...and nothing else broke while doing this, that is also a good thing (IMG:style_emoticons/default/smile.gif) |
mark04usa |
Sep 15 2016, 01:14 PM
Great to see that you have well sorted the breather! (IMG:style_emoticons/default/smilie_pokal.gif) Not sure what the valve does, likely it is for gases to flow only one direction. The parts diagrams and info are available at the Porsche website here:
http://www.porsche.com/all/media/pdf/origi...914_KATALOG.pdf |
era vulgaris |
Sep 15 2016, 02:17 PM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
Lo-Fi Version | Time is now: 17th June 2024 - 11:58 AM |
