| BeemerSteve |
Sep 14 2016, 04:44 PM
Member ![]() ![]() Group: Members Posts: 239 Joined: 2-September 15 From: Van Zandt, Wa Member No.: 19,123 Region Association: Pacific Northwest |
Wondering how I can find out if my throttle body shaft is worn? After deceleration down to an idle it has a tendency to stick at a higher rpm. Is it time for a rebuild even if I can?
Could it be something else? Thank you kind sirs!!! |
| dlee6204 |
Sep 14 2016, 06:47 PM
Howdy ![]() ![]() ![]() ![]() Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
It could simply be dirty and need cleaning. Could also be a weak return spring.
| BeemerSteve |
Sep 14 2016, 07:17 PM
It could simply be dirty and need cleaning. Could also be a weak return spring. I think you could be right about being dirty if that would in fact cause this. Return spring is new. I think I might take it off this weekend and at least access the butterfly or shaft for wear. |
| Rob-O |
Sep 14 2016, 08:24 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,319 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region
is this with or without the accelerator pedal connected?
| Krieger |
Sep 14 2016, 08:53 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,879 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
What do you mean when you say it sticks at high rpm? The throttle plate stays open and is not closing after taking your foot off the pedal or after lifting off the throttle the RPMs stay high?
| PancakePorsche |
Sep 14 2016, 10:50 PM
Member ![]() ![]() Group: Members Posts: 236 Joined: 29-July 11 From: Southern California Member No.: 13,373 Region Association: None |
Want a real nice throttle feel ? Have the body bronze bushed and lube with tri-flow spray. Night and day difference. Don't even mess with a worn T.B.
I used bushings I found at a true Value hardware store and machined to fit. 2 hours and $10. |
| BeemerSteve |
Sep 15 2016, 07:46 AM
| BeemerSteve |
Sep 15 2016, 07:49 AM
What do you mean when you say it sticks at high rpm? The throttle plate stays open and is not closing after taking your foot off the pedal or after lifting off the throttle the RPMs stay high? Sorry, worded wrong. When it comes back down to an idle the idle is high until I blip the pedal then it settles to a normal idle. Before I blip the throttle it runs at 2,000 rpm. |
| BeemerSteve |
Sep 15 2016, 07:50 AM
| Krieger |
Sep 15 2016, 08:03 AM
So IF the throttle plate is closed and it idles too high you might have a problem with your distributor retarding the timing.
| andreic |
Sep 15 2016, 08:28 AM
Member ![]() ![]() Group: Members Posts: 172 Joined: 21-December 15 From: Madison, WI Member No.: 19,479 Region Association: Upper MidWest |
Well, I'd like to find out the answer to this myself. I have the same exact problem: normally it'll idle at 1800-1900 RPM. But if I try to close back the throttle by hand by applying hard pressure, or if I hold the car in gear and don't press the clutch as I come to a stop until the RPM goes down to 900, it'll stay at 900.
I tried three different throttle bodies for this, and the problem is exactly the same. I started to suspect it is in the distributor -- I think sometimes it pulls back the timing (with the vacuum from the retard portion of the throttle body), and sometimes maybe it gets stuck and does not retard it. But I don't know how to check that this is really the case. |
| Mikey914 |
Sep 15 2016, 10:46 AM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,784 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
More than likely just dirty, I know they can be rebuilt, but may be easier (faster) to buy a "new" one. The other issue can be tension on the throttle cable. The pedals can start to come apart at the hinge over time and change the geometry so that it sits of ft the side more. This can make the return job of the spring harder so it will not return "as fast" if it can at all. Many just add a larger spring back in the engine compartment, but if this is your case it's only a matter of time before it will fail.
| Rob-O |
Sep 15 2016, 11:06 AM
Not a whole lot of information in your reply. Let's start again. So you've disconnected the throttle cable from the throttle body and have actuated the TB by hand and this problem is still there? Just trying to help by being methodical in the approach to solving the issue. And thought I'd start at the accelerator cable. If the TB is sticky when the throttle cable is disconnected, you'll feel it when you actuate it by hand. If it opens and closes cleanly then it's in vacuum somewhere. |
| BeemerSteve |
Sep 15 2016, 12:09 PM
[quote name='Rob-O' date='Sep 15 2016, 10:06 AM' post='2398761']
[quote name='BeemerSteve' post='2398676' date='Sep 15 2016, 05:46 AM'] [quote name='Rob-O' post='2398514' date='Sep 14 2016, 07:24 PM'] is this with or without the accelerator pedal connected? [/quote] Yes. [/quote] Not a whole lot of information in your reply. Let's start again. So you've disconnected the throttle cable from the throttle body and have actuated the TB by hand and this problem is still there? Just trying to help by being methodical in the approach to solving the issue. And thought I'd start at the accelerator cable. If the TB is sticky when the throttle cable is disconnected, you'll feel it when you actuate it by hand. If it opens and closes cleanly then it's in vacuum somewhere. [/quote Thanks....I will check that this evening and report ] |
| nihil44 |
Sep 15 2016, 03:39 PM
Member ![]() ![]() Group: Members Posts: 157 Joined: 28-January 12 From: Brisbane, Australia Member No.: 14,058 Region Association: None
If considering a TB rebuild, refer to this post http://www.914world.com/bbs2/index.php?sho...amp;hl=TB+samba |
| Rob-O |
Sep 15 2016, 04:32 PM
I had my TB done by Phil, looked just like those pictures (I started my own thread about it sometime afterwards).
TB is beautiful, but it was $300 and some change for the rebuild. |
Lo-Fi Version | Time is now: 16th September 2026 - 12:03 AM |
