cpavlenko |
Member ![]() ![]() Group: Members Posts: 489 Joined: 19-April 12 From: North Arizona Member No.: 14,400 Region Association: Southwest Region ![]() |
what type gaskets for 1971 1.7, I've heard there tricky to get them in right. Also what type of gasket sealer is recommended?
jcd914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,096 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California ![]() |
I have always used gasgacinch to stick the cork gasket to the valve cover.
After the gasgacinch dries, I smear a thin coating of swepco 101 moly grease on the head side of the gasket. Then the gasket does not stick to the head and the cover can be shifted around to make sure it is seated. I often reused the old gaskets several times this way. Jim |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,181 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Get some of 914Rubber high temp reusable gaskets and be done.
cpavlenko |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
The cork are cheap and stick well. If you use the silicone, cleaned and decrease, if you want a small amount of silicone to glue in place.
Mark |
cpavlenko |
euro911 |
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,911 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California ![]() ![]() |
I recommend the thicker cork gaskets that Mark (914 Rubber) makes.
I just smear a bit of hi-temp grease on both sides of the gaskets. The grease helps to keep them in place, as well as keeping oil from seeping through. |
cpavlenko |
I recommend the thicker cork gaskets that Mark (914 Rubber) makes. I just smear a bit of hi-temp grease on both sides of the gaskets. The grease helps to keep them in place, as well as keeping oil from seeping through. Hi Mark, hows things going at Payson. Thanks for the info. One day I'll take a trip to your neck of the woods. PM me your phone# and address. I'm still learning a lot on the 914. I now know how to adjust the valves correctly. Live and learn the hard way, but it wasn't as hard as I thought it would be. Just a PITA for a 62 yr old guy under that teener. Hope to here from you. |
euro911 |
I recommend the thicker cork gaskets that Mark (914 Rubber) makes. Hi Mark, hows things going at Payson. Thanks for the info. One day I'll take a trip to your neck of the woods. PM me your phone# and address. I'm still learning a lot on the 914. I now know how to adjust the valves correctly. Live and learn the hard way, but it wasn't as hard as I thought it would be. Just a PITA for a 62 yr old guy under that teener. Hope to here from you.I just smear a bit of hi-temp grease on both sides of the gaskets. The grease helps to keep them in place, as well as keeping oil from seeping through. Having a lift is a real plus for working on these cars, even one of the smaller mid-rise lifts. In fact, a mid-rise is also great for changing tires, doing brakes & suspension work (IMG:style_emoticons/default/cool_shades.gif) (I'll have to buy another 4-post for tha AZ home - sold mine to my old shop's landlord). I'm in CA right now, have a good-sized list of 'honey-doos' to complete. I'm continually adding to the list of stuff I need to take to AZ + staging it right now. I also have to source a new control board for my furnace before going back ... I think it's gonna be late fall or winter by then (IMG:style_emoticons/default/dry.gif) I'll PM you the pertinent info and let you know when I plan to be in AZ again. |
cpavlenko |
I recommend the thicker cork gaskets that Mark (914 Rubber) makes. Hi Mark, hows things going at Payson. Thanks for the info. One day I'll take a trip to your neck of the woods. PM me your phone# and address. I'm still learning a lot on the 914. I now know how to adjust the valves correctly. Live and learn the hard way, but it wasn't as hard as I thought it would be. Just a PITA for a 62 yr old guy under that teener. Hope to here from you.I just smear a bit of hi-temp grease on both sides of the gaskets. The grease helps to keep them in place, as well as keeping oil from seeping through. Having a lift is a real plus for working on these cars, even one of the smaller mid-rise lifts. In fact, a mid-rise is also great for changing tires, doing brakes & suspension work (IMG:style_emoticons/default/cool_shades.gif) (I'll have to buy another 4-post for tha AZ home - sold mine to my old shop's landlord). I'm in CA right now, have a good-sized list of 'honey-doos' to complete. I'm continually adding to the list of stuff I need to take to AZ + staging it right now. I also have to source a new control board for my furnace before going back ... I think it's gonna be late fall or winter by then (IMG:style_emoticons/default/dry.gif) I'll PM you the pertinent info and let you know when I plan to be in AZ again. Sounds good, if u need any help, let me know. Take care. |
JawjaPorsche |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States ![]() |
I recommend the thicker cork gaskets that Mark (914 Rubber) makes. I just smear a bit of hi-temp grease on both sides of the gaskets. The grease helps to keep them in place, as well as keeping oil from seeping through. (IMG:style_emoticons/default/agree.gif) I used to get small leaks until I started using 914Rubber's thicker gaskets! Problem solved! |
Frankvw |
working on my first 914 ! ![]() ![]() ![]() Group: Members Posts: 653 Joined: 13-April 16 From: Holland, the Netherlands Member No.: 19,896 Region Association: Europe ![]() |
I can speak from my experience in the VW world (Type1, but also Type4 engines) that I never used any adhesive, sealant or anything like that when installing the cork valvecover gaskets.
When the snapped on coverholder does not have enough tension to keep the cover firm in its spot, it can leak and if the valve cover is warped same thing. If the valvecover is straight and there is enough pressure to hold the cover there should be no need for any product to add. I know there is a difference in cork-gasket quality, the Original VW ones are really good, so maybe poor quality gaskets can change things to use.... |
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,752 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() ![]() |
In my experience, if you use a LITTLE smear of RTV between the gasket and the valve cover, nothing is needed between the gasket and the head.
Also, the gaskets will last years this way without leaking, even after opening the covers up for regular valve adjustments. Zach |
Mikey914 |
I can speak from my experience in the VW world (Type1, but also Type4 engines) that I never used any adhesive, sealant or anything like that when installing the cork valvecover gaskets. When the snapped on coverholder does not have enough tension to keep the cover firm in its spot, it can leak and if the valve cover is warped same thing. If the valvecover is straight and there is enough pressure to hold the cover there should be no need for any product to add. I know there is a difference in cork-gasket quality, the Original VW ones are really good, so maybe poor quality gaskets can change things to use.... This could be the real issue. I know that there are other valve cover gaskets that sell at about what my raw material cost is for these. You can make stuff in China, but the material cost will not have much variation, unless you make it cheaper somehow??? It's the only way they could sell at the prices they do and have any margin. Oh and by the way we did make our sealing surface slightly wider. |
Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
"Elliot is older". And smarter, better looking, faster driver, etc. etc. (IMG:style_emoticons/default/av-943.gif)
Elliot Cannon |
euro911 |
"Elliot is older". And smarter, better looking, faster driver, etc. etc. (IMG:style_emoticons/default/av-943.gif) Choo gottit, mang ... except for the 'faster driver' part (IMG:style_emoticons/default/laugh.gif) |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,248 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
I'd be hard pressed to hack up a set of 2.0 tin to provide those vent tubes. Or any set for that matter. Note the carb intake. The cinch-a-gasket works well on the stock cover side. Only! Install the cover with the VW symbol upside down, iirc.
cpavlenko |
Elliot Cannon |
I'd be hard pressed to hack up a set of 2.0 tin to provide those vent tubes. Or any set for that matter. Note the carb intake. The cinch-a-gasket works well on the stock cover side. Only! Install the cover with the VW symbol upside down, iirc. Did you miss the point of the article? (IMG:style_emoticons/default/biggrin.gif) You know, valve cover gaskets? |
Lo-Fi Version | Time is now: 2nd July 2025 - 01:19 PM |
