Viable way of bigger cv joints on the rear? |
tazz9924 |
Sep 22 2016, 11:05 AM
Senior Member Group: Members Posts: 703 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
I saw these on patrick motorsports and i was confused do these bolt up to the 914 or do ineed somthing else? also are these just junk? http://www.patrickmotorsports.com/part/rea...4-transmission/
tazz9924 |
Sep 22 2016, 11:12 AM
Also do they work on the outer
VaccaRabite |
Sep 22 2016, 11:18 AM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
IIRC T1 Beetle CVs work just fine for a 914.
Those aren't junk but you need a fair bit of modification to make them work, and you need to be putting down a fair bit of power to make them worth while. Zach |
tazz9924 |
Sep 22 2016, 11:25 AM
IIRC T1 Beetle CVs work just fine for a 914. Those aren't junk but you need a fair bit of modification to make them work, and you need to be putting down a fair bit of power to make them worth while. Zach Yeah i make 260 but i don't want to be afraid of outer cvs bursting all the time |
Mike Bellis |
Sep 22 2016, 06:10 PM
I saw these on patrick motorsports and i was confused do these bolt up to the 914 or do ineed somthing else? also are these just junk? http://www.patrickmotorsports.com/part/rea...4-transmission/ Yes, Those bolt to the tranny and wheel flange (stock 914) and allow the use of a 930 turbo CV. I bought a pair and use them to modify an Audi output flange to run 930 CV's. Very high quality product. |
Steve |
Sep 23 2016, 07:03 AM
914 Guru Group: Members Posts: 5,606 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
PMS is a quick bolt in with stock flanges. If your converting to 5 bolt, this thread is what I did.
http://www.914world.com/bbs2/index.php?showtopic=91963 There is also another thread in that forum using 100mm 944 cv's. |
tazz9924 |
Sep 23 2016, 07:44 PM
PMS is a quick bolt in with stock flanges. If your converting to 5 bolt, this thread is what I did. http://www.914world.com/bbs2/index.php?showtopic=91963 There is also another thread in that forum using 100mm 944 cv's. all i need is one on the wheel side and that should bolt up right? |
Steve |
Sep 23 2016, 07:58 PM
It's all covered in the thread. 108mm trans flanges, 930 swayaway axles, early 70's 911 cv's, stub axles, disks, etc.
tazz9924 |
Sep 23 2016, 11:47 PM
mepstein |
Sep 24 2016, 05:59 AM
914-6 GT in waiting Group: Members Posts: 19,307 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Lo-Fi Version | Time is now: 2nd June 2024 - 08:21 AM |
