EdwardBlume |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California ![]() ![]() |
I've been working on Dads car and I'm about to move on to the rear trunk. The battery side has been raised annoyingly for years and I want it fixed.
The trunk hinge pivot is loose on the offending side. The spring / torsion is disconnected. I have a newer latch spring. I have the bolt on latch hinge replacement. The issue? I can't tell if the issue is the hinge, the trunk (i.e. Bent), the latch, or a combination? Anybody been down this road before? Attached thumbnail(s) ![]() |
Millerwelds |
Pleepleus ![]() ![]() ![]() Group: Members Posts: 715 Joined: 24-June 08 From: Grass Valley, CA Member No.: 9,206 Region Association: Northern California ![]() |
I suspect gravity is causing it to lift like that. Perhaps flip it onto it's wheels and see if the lid settles. (IMG:style_emoticons/default/beerchug.gif) |
cary |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest ![]() ![]() |
The pivot is what sets the level. Being disconnected and are broken could have tweaked the left hinge, which could be adding to you lift. Making it worse.
You need to get the pivot replaced to get the process started. http://www.914world.com/bbs2/index.php?s=&...t&p=2396818 |
Larmo63 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California ![]() |
JawjaPorsche |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States ![]() |
I say do the best you can and don't sweat it.
Twenty years ago my driver's pivot came off. I had it rewelded. The welder liked my 914 so much he did not charge me. When I replaced my trunk it was a tad higher (2 mm). After figuring out the cause, I realized I would probably be the only one to notice it. |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,437 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
Attached image(s) ![]() |
Perry Kiehl Clone |
Unregistered ![]() |
You've got to fix the pivot location, as it's gotten raised up from pulling loose.
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,570 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
I've been working on Dads car and I'm about to move on to the rear trunk. The battery side has been raised annoyingly for years and I want it fixed. The trunk hinge pivot is loose on the offending side. The spring / torsion is disconnected. I have a newer latch spring. I have the bolt on latch hinge replacement. The issue? I can't tell if the issue is the hinge, the trunk (i.e. Bent), the latch, or a combination? Anybody been down this road before? At some point you'll probably have to look at it and use some common sense. |
amfab |
Member ![]() ![]() Group: Members Posts: 393 Joined: 17-May 16 From: Los Angeles Member No.: 20,004 Region Association: None ![]() ![]() |
I just went down that road. Replaced mine with:
http://www.jwesteng.com/shop/914/10-914-re...runk-pivot.html Seems to be the best solution. -Andrew |
cary |
Whether you go with a weld in or JWest pivot. After you get the previous welds ground down. Check to make sure the parent material in the tub is in good condition. It's taken 40 plus years of debris being thrown at it in the fender wheel.
EdwardBlume |
Whether you go with a weld in or JWest pivot. After you get the previous welds ground down. Check to make sure the parent material in the tub is in good condition. It's taken 40 plus years of debris being thrown at it in the fender wheel. Great point. This area was rebuilt years ago so the area is in really good condition. The drivers side got welded 15+ years ago but then the pass gave way. |
cary |
Giving each pivot 3-4 drops of oil every year needs to become part of our maintenance plan. One side seizes up, and the other doesnt. Then you have the leverage of the big hood. Then pow, pivot gets ripped out.
EdwardBlume |
Its fixed now.
"Someone" disconnected the torsion bars and the ends were sticking straight up and keeping the trunk from sitting down. Stupid driving around like that for years.... I just pulled the bars out.... I shimmed the trunk up slightly and aligned the engine lid while I was in there. Now I just need trunk shocks... |
EdwardBlume |
As she sits now...
Millerwelds |
As she sits now... See, back on its wheels and now it looks fine. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 14th June 2024 - 03:25 PM |
