What is this switch under the dash? |
surfdogskier |
Oct 4 2016, 01:25 PM
Member Group: Members Posts: 164 Joined: 20-May 16 From: East TN Member No.: 20,019 Region Association: None |
I have no idea what this is or does. I can't find anything on it. It is a turning switch with a wire attached to it. I havent tore my dash apart yet to figure out where it goes. It is a turn style switch. I wondered if it was some type of kill switch since I can't start my car for the life of me. Do any of you have this or is this stock?
Attached image(s) |
db9146 |
Oct 4 2016, 01:32 PM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
Its the odometer reset. Twist it and it rolls through all of the digits on the odometer to reset it to "0000".
SirAndy |
Oct 4 2016, 02:09 PM
Resident German Group: Admin Posts: 41,675 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Its the odometer reset. Twist it and it rolls through all of the digits on the odometer to reset it to "0000". (IMG:style_emoticons/default/agree.gif) |
PanelBilly |
Oct 4 2016, 02:13 PM
914 Guru Group: Members Posts: 5,816 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Turns the rust preventative system off. Once this has been activated the car begins to fall apart.
TheCabinetmaker |
Oct 4 2016, 02:24 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Ejection seat switch
Catorse |
Oct 4 2016, 02:25 PM
Member Group: Members Posts: 194 Joined: 27-August 15 From: Los Angeles Member No.: 19,106 Region Association: Southwest Region |
Muffler bearing oiling port
Frankvw |
Oct 4 2016, 02:31 PM
working on my first 914 ! Group: Members Posts: 651 Joined: 13-April 16 From: Holland, the Netherlands Member No.: 19,896 Region Association: Europe |
On a serious note: do NOT turn it while driving....
surfdogskier |
Oct 4 2016, 02:55 PM
Ejection seat switch Is there any way I can switch it to the passenger side?....I could use it on a few people I know.... (IMG:style_emoticons/default/happy11.gif) |
surfdogskier |
Oct 4 2016, 02:58 PM
Thanks guys for the input!... (IMG:style_emoticons/default/beerchug.gif)
rfinegan |
Oct 4 2016, 03:27 PM
Senior Member Group: Members Posts: 973 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
TheCabinetmaker |
Oct 4 2016, 03:38 PM
Ejection seat switch Is there any way I can switch it to the passenger side?....I could use it on a few people I know.... (IMG:style_emoticons/default/happy11.gif) Yes. Just switch the wires around. (IMG:style_emoticons/default/beerchug.gif) |
BillC |
Oct 4 2016, 04:53 PM
Senior Member Group: Members Posts: 546 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
It looks like it might be missing the knob that goes on the shaft. It'll be harder to turn without the knob. IIRC, the knob is held on with a set screw, which probably came loose and let the knob fall off.
Rand |
Oct 4 2016, 05:03 PM
Ejection seat switch Is there any way I can switch it to the passenger side?....I could use it on a few people I know.... (IMG:style_emoticons/default/happy11.gif) Yes. Just switch the wires around. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/laugh.gif) I won't crack a joke about the knob being in the drivers seat. Love this group. |
theleschyouknow |
Oct 4 2016, 06:13 PM
Senior Member Group: Members Posts: 523 Joined: 4-June 13 From: Texas Member No.: 15,967 Region Association: None |
I heard or read this somewhere recently (probably on here) but I liked it
always check the nut holding the wheel first (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/beerchug.gif) cjl |
Alfieg23 |
Oct 5 2016, 02:22 PM
Newbie Group: Members Posts: 44 Joined: 7-January 14 From: Miramar, Florida Member No.: 16,854 Region Association: South East States |
Is this reset knob accessible if my car has the A/C vents running along the bottom of the dash? I can't seem to locate it.
I heard or read this somewhere recently (probably on here) but I liked it always check the nut holding the wheel first (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/beerchug.gif) cjl |
malcolm2 |
Oct 5 2016, 02:38 PM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
Its the odometer reset. Twist it and it rolls through all of the digits on the odometer to reset it to "0000". "0000" if you are lucky..... mine stops on 0010 every damn time. drives me crazy. And mine is not attached to the btm of the dash. Some PO pulled it out and re-installed the nut (that rusted) so mine just dangles, never to be attached again. |
malcolm2 |
Oct 5 2016, 02:40 PM
hey, where are you in East TN. Good to see another Tennessean on the board.
I am in Mount Juliet. |
Frankvw |
Oct 5 2016, 03:44 PM
"Is this reset knob accessible if my car has the A/C vents running along the bottom of the dash? "
YES. I have that and it is there.... |
TheCabinetmaker |
Oct 5 2016, 04:55 PM
Its the odometer reset. Twist it and it rolls through all of the digits on the odometer to reset it to "0000". "0000" if you are lucky..... mine stops on 0010 every damn time. drives me crazy. And mine is not attached to the btm of the dash. Some PO pulled it out and re-installed the nut (that rusted) so mine just dangles, never to be attached again. Just pull it out of the back of the Speedo can. Its just poked in a hole. Unrust it, and stick it back in. (IMG:style_emoticons/default/beer3.gif) |
poorsche914 |
Oct 5 2016, 06:33 PM
T4 Supercharged Group: Members Posts: 3,091 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
hey, where are you in East TN. Good to see another Tennessean on the board. I am in Mount Juliet. He's in my neck of the woods... Sevierville. Trying to find time to go over and help him get things straightened out. (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 7th June 2024 - 12:17 AM |
