AMC Cylinder Heads, What is your experience? |
914_teener |
Oct 4 2016, 05:49 PM
914 Guru Group: Members Posts: 5,205 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Looking for feedback for the the above thread topic because I am getting ready to drop the dime:
What is your set up...ie compression ratio...cam...ect.? Where did you get them? Need the feedback for my 2056 build and this is one of the last big items. I plan on running d-jet...modified for the bigger jugs. Thank in Advance folks. |
Dominic |
Oct 4 2016, 06:37 PM
Dominic Group: Members Posts: 992 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California |
Looking for feedback for the the above thread topic because I am getting ready to drop the dime: What is your set up...ie compression ratio...cam...ect.? Where did you get them? Need the feedback for my 2056 build and this is one of the last big items. I plan on running d-jet...modified for the bigger jugs. Thank in Advance folks. I got mine from the Type 4 store many moons ago, but they are highly modified for the 2270 I built (I think they are the LE 200 heads). They start out as new AMC castings, so they are much easier to modify (weld/machine) than used (heat cycled) heads. |
HAM Inc |
Oct 4 2016, 06:48 PM
Senior Member Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
The castings are great, the parts are crap, including the valve seats and guides.
We throw away everything but the fasterners; they're actually pretty good. |
theleschyouknow |
Oct 4 2016, 07:08 PM
Senior Member Group: Members Posts: 523 Joined: 4-June 13 From: Texas Member No.: 15,967 Region Association: None |
The castings are great, the parts are crap, including the valve seats and guides. We throw away everything but the fasterners; they're actually pretty good. just curious are these your preferred option, the only option or just a good option once you replace all the crap parts? my long term (IMG:style_emoticons/default/beerchug.gif) cjl |
HAM Inc |
Oct 4 2016, 07:23 PM
The castings are great, the parts are crap, including the valve seats and guides. We throw away everything but the fasterners; they're actually pretty good. just curious are these your preferred option, the only option or just a good option once you replace all the crap parts? my long term (IMG:style_emoticons/default/beerchug.gif) cjl It's the only option from our shop. We stopped working with used T4 heads in 2014. AMC doesn't offer a 2.0 914 head. They only offer 2.0 bus heads. We convert them to 2.0 914 specs, including CNC machined chambers, and ports along with 3 intake studs and M10 temp sensor threads. That makes them plug and play replacements for the O.E. heads and work with the factory F.I. |
914_teener |
Oct 4 2016, 07:43 PM
So Len you are still doing them.
I know quite a few people who are replacing 2.0 heads from cycling cracks it just is not worth it to pull them after a year due to a cracked head. DRD sells them but they run them with the seats and valves that come with them. Anybody else? |
HAM Inc |
Oct 4 2016, 08:17 PM
So Len you are still doing them. I know quite a few people who are replacing 2.0 heads from cycling cracks it just is not worth it to pull them after a year due to a cracked head. DRD sells them but they run them with the seats and valves that come with them. Anybody else? Still doing new heads? Yes. Used heads? No. The valves and seats and guides and springs and retainers that come in the amc heads are crap. And even if they weren't, the valves are 2.0 bus sized; 39mm x 33mm. Much smaller than the 42 x 36 valves that the 2.0 914's came with. |
HAM Inc |
Oct 5 2016, 06:25 AM
This is worth a quick view.
https://www.youtube.com/watch?v=Z69UualaQMk https://www.youtube.com/watch?v=Z69UualaQMk |
McMark |
Oct 5 2016, 09:09 AM
Whoa.... (IMG:style_emoticons/default/blink.gif)
Lo-Fi Version | Time is now: 10th June 2024 - 09:54 AM |
