Hey , can this work?, steering wheel quick release |
blk'72 |
Apr 18 2005, 05:38 PM
Member Group: Members Posts: 83 Joined: 2-November 04 From: Pleasanton, CA Member No.: 3,053 |
looking at buying this.....I dont know what I need to fit our teeners.... universal ball bearing quick release kit for any cars equipped with after market hubs. Ball bearing swivel mechanism, slide the steering wheel onto the hub and swivel the steering wheel will lock itself into place the steering wheel off same position you took the (goes on one way). Kit also act as a 50mm spacer by pulling the steering wheel towards the driver, comes with wires to hook up horn button with the grounding plates from the existing steering wheel hub. In addition, the kit act as anti-theft mechanism where most thefts will be discouraged in stealing the car without a steering wheel! Condition: BRAND NEW IN ORIGINAL BOX, NEVER BEEN TRIED ON AND USED ??? (IMG:http://www.914world.com/bbs2/html/emoticons/mueba.gif) seems pretty simple, but which set up do you guys have? I would buy this right now if I was sure it could work on my car.....I have a hub on there from the previous owner, not a momo, not a grant ....I dunno (IMG:http://www.914world.com/bbs2/html/emoticons/chairfall.gif) ...but he had an aftermarket steering wheel, with no name brand on it..... Anyone up to answer my questions in Pleasanton? R. |
BatFromHell |
Apr 18 2005, 05:43 PM
Newbie Group: Members Posts: 25 Joined: 7-April 05 From: Ontario,Canada Member No.: 3,890 |
Make sure spline on your car steering shaft matches spline on hub if it has one.
If it is weld on type and O.D. of steering shaft matches I.D. of hub. Bob's yur Uncle. |
blk'72 |
Apr 18 2005, 05:50 PM
yo bob my uncle/ I SPEAK ENGLISH AS A SECOND LANGUAGE (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif)
Everything you just said doesnt make sense to MOI. Please explain..... -what is the spline on my car steering shaft and how does it match others??? Tx (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) R. |
Joe Bob |
Apr 18 2005, 06:13 PM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
The quick release mechanism is two pieces....
The first piece needs to fit the 914 spline on the steering column. The second piece THEN needs to be compatible with the steering wheel you chose..... So...best to buy the QR and the steering wheel from the same manufacturer... |
BatFromHell |
Apr 18 2005, 06:17 PM
Splines are vertical "teeth" (male set) that are machined in at the end of the steering shaft and the hub has a set of exact same vertical "teeth" machined in on it (female set). This allows the hub to be
pressed onto the shaft and therefore allow the steering wheel (when mounted onto the hub) to turn the shaft. See pic. "Teeth" on end of transmission main shaft are called "splines". Should have similar "teeth" on steering shaft. I.D. = inner diameter O.D. = outer diameter Attached image(s) |
Jeroen |
Apr 18 2005, 07:18 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
Mueller |
Apr 18 2005, 07:31 PM
those are pretty good prices on quite a bunch of his stuff...thanks for the link... |
machina |
Apr 18 2005, 07:34 PM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
i like this QR because it is super low profile. you don't need any hub adapter if you have a momo wheel pattern. the splined sleeve fits right on the shaft.
http://www.ogracing.com/eshop/home.asp?categ=164 Attached image(s) |
jonwatts |
Apr 18 2005, 08:12 PM
no rules, just wrong Group: Benefactors Posts: 2,321 Joined: 13-January 03 From: San Jose, CA Member No.: 141 |
If you follow the link to his ebay store you realize his prices are better than what's listed on the site. I just bought this Type-2, (haven't received it yet). The description sounds exactly the same as what blk'72 was asking about, so to answer your original question, this thing is in two parts and mounts between the hub and the steering wheel. I believe the type-2 only works with the MOMO / Sparco bolt pattern, so you should check your steering wheel bolt spacing to make sure it's compatible (I think the MOMO spacing is 70mm). Thanks Jeroen for originally tipping us off to this guy many many months ago (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif) |
blk'72 |
Apr 18 2005, 11:04 PM
kool guys, thanks for the info.
Its always good to learn new stuff. R. |
Oracle |
Apr 21 2005, 02:14 PM
Newbie Group: Members Posts: 21 Joined: 28-March 05 From: San Diego, CA Member No.: 3,834 |
jonwatts ,
Just curious if you received the type-2 quick release yet? If so, did it work? I ordered one myself (mainly as a theft deterrent), but I'm not sure if it will fit my "personal" brand steering wheel. |
Lo-Fi Version | Time is now: 4th June 2024 - 05:09 PM |
