3.2 On the Road, And into cold storage WI winter coming |
worn |
Oct 6 2016, 08:51 AM
can't remember Group: Members Posts: 3,164 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Well I have gotten everything but a small punch list finished and in the end had to roll out the fenders. I bought a roller like in eastwood from Amazon for about $50 and it came without instructions. So I jacked up the car, modified the hub holes on the unit so they fit, which they didn't at first, and installed it.
Not really knowing what to do I got into the car, started her up and eased into 1st. Then I sort of dumped the clutch. There was a sudden whacky whacky crashing, the car leaped off the jack stand and started limping forward as the fender stretcher came round to ground with each spin. Put the wheel back n and it was perfect. Note: if anyone is looking for instruction: I did NOT do that. I was hoping to raise some eyebrows about technique, but realize that someone might perhaps believe it. Actually the unit did the job. So I was ready to go. However, the salt may hit the road without warning this time of year, so into the storage garage it goes. I got to drive it about 40 miles. Original 5th gear is now 4th and the new 5th is a flipped HB from Dr Evil. The springs I chose are perfect: Original 911 torsion bars up front and 175 coil overs from Coleman in back. Blisters from PMB. That means Bilstein in spell check/correct. |
Cairo94507 |
Oct 6 2016, 09:12 PM
Michael Group: Members Posts: 9,828 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Worn - Very cool but we need to see pics of the fenders and the 3.2. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/beerchug.gif)
mb911 |
Oct 7 2016, 05:13 AM
914 Guru Group: Members Posts: 6,883 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Agreed
worn |
Oct 7 2016, 08:02 AM
Agreed OK. I have never had a speeding ticket in almost 50 years of driving. I was doing 90 before I knew it. The white 914 is set real low and harsh. This one seems more stable at speed and a lot more comfortable. I love it and am glad I did it. Going out to visit it today and start reassembling the 911 motor so I will try to bring the camera. As far as motor: I think I posted this before. I am trying to put together the things that went into the car. I made as much of the stuff as I could including the alu oil tank. Maybe a build thread. |
mbseto |
Oct 7 2016, 08:18 AM
Senior Member Group: Members Posts: 1,253 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States |
orthobiz |
Oct 7 2016, 12:19 PM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
I live in salty Michigan. I've had good luck with storage from Nov 1 until May 1. I think you have at least two more weeks of driving!!
Paul |
Lo-Fi Version | Time is now: 11th June 2024 - 04:20 AM |
