Well I have gotten everything but a small punch list finished and in the end had to roll out the fenders. I bought a roller like in eastwood from Amazon for about $50 and it came without instructions. So I jacked up the car, modified the hub holes on the unit so they fit, which they didn't at first, and installed it.
Not really knowing what to do I got into the car, started her up and eased into 1st. Then I sort of dumped the clutch. There was a sudden whacky whacky crashing, the car leaped off the jack stand and started limping forward as the fender stretcher came round to ground with each spin. Put the wheel back n and it was perfect.
Note: if anyone is looking for instruction: I did NOT do that. I was hoping to raise some eyebrows about technique, but realize that someone might perhaps believe it.
Actually the unit did the job. So I was ready to go. However, the salt may hit the road without warning this time of year, so into the storage garage it goes. I got to drive it about 40 miles. Original 5th gear is now 4th and the new 5th is a flipped HB from Dr Evil. The springs I chose are perfect: Original 911 torsion bars up front and 175 coil overs from Coleman in back. Blisters from PMB. That means Bilstein in spell check/correct.
