Speedo bounce, 3 Speedo's and they all bounce |
tracks914 |
Apr 18 2005, 08:10 PM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
I've had 3 different speedo's in my car and they all bounce (3-5mph) the needle between 20 and 70mph. I am going to redo the tranny next week and was wondering if it might be the cable or the speedo drive causing the bouncy needle thingy. Either way I'd like to fix it when I have the car up on stands.
lapuwali |
Apr 18 2005, 08:19 PM
Very likely a bad cable.
Aaron Cox |
Apr 18 2005, 08:20 PM
mine got better with a new speedo cable and angle drive....
skline |
Sounds like a kink in the cable. Once it is there, it will always be there. Change the cable and it should resolve.
ThinAir |
Apr 19 2005, 09:05 AM
Best friends Group: Members Posts: 2,542 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
Mine had this problem when the angle-drive was leaking tranny fluid into the cable. I'd replace the cable and/or get the speedo serviced and it would be back again very soon. The direction of rotation on the cable just wicks the fluid right up into the speedo and gunks up the whole thing. I solved the problem by going to an electronic speedo and then disassembling the whole car to restore it. If it ever gets put back together I'll deal with the angle-drive then.
Joe Bob |
Apr 19 2005, 09:08 AM
Pull the cable at the angle drive....put a drill motor on the cable end...and spin it up...if it still jumps...cable. If it works fine it's most likely the angle drive.
Root_Werks |
Apr 19 2005, 10:04 AM
Village Idiot Group: Members Posts: 8,321 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) What he said. |
airsix |
Apr 19 2005, 10:32 AM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
Where I grew up (just outside Yellowstone) we all had bouncing speedos because of the cold winters. If you use reverse when it's -30F outside the 'wire rope' (speedo cable) turns against the twist and unwinds and from that point on is always springy hence the speedo bounce.
-Ben M. |
Rouser |
Apr 19 2005, 02:20 PM
Anti-Post Whore Group: Benefactors Posts: 597 Joined: 30-December 02 From: Citrus Park, Florida Member No.: 54 |
Yep, what he said. Nothing wrong with the speedos; your cable has a kink in it. |
meares |
Apr 19 2005, 07:47 PM
Member Group: Members Posts: 403 Joined: 23-March 05 From: Atlanta Member No.: 3,800 |
Z.....keep the avatars!!!! they're cool!
Rgreen914 |
Apr 19 2005, 07:53 PM
Member Group: Members Posts: 285 Joined: 20-October 03 From: West Covina, Ca. Member No.: 1,266 |
Once had that problem on an American car; took the cable out, cleaned and greased it. Put it back in and no more problems.
Ron |
Lo-Fi Version | Time is now: 23rd May 2024 - 12:24 PM |
