Question about chasis number locations |
Luke15 |
Oct 8 2016, 02:21 PM
Newbie Group: Members Posts: 10 Joined: 6-August 16 From: Baltimore Member No.: 20,268 Region Association: None |
Hi- I have a 1972 914 and I am trying to find where my chasis numbers are? How many are there and where is the one on the engine? I have looked and cannot find it. Thanks. Luke |
914Sixer |
Oct 9 2016, 06:45 AM
914 Guru Group: Members Posts: 8,902 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Chassis number will be in two places: Stamped in the right hand side corner of the trunk floor and on the Karman plate in the front of the door jamb.
Engine number will be stamped on the rib top at the transmission end IF it is an original engine. Number should start with W0--------- |
Tom_T |
Oct 10 2016, 10:27 AM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
.... and the VIN will be in 4 placs (5 on some) - in the front trunk in 2 places ; stamped on the top of the passenger wheelwell & on the plate on the pass. side headlight bucket; 1 on the driver side windshield frame; 1 on the VIN sticker on the rear driver door jamb; & some have it written in marker on the frame under the dash. The transaxle case no. is on the middle area of the center rib on the bottom of the case. You can find charts with the numbers in the 914 info section on here, plus loads of info & pix of where they are & what they look like on Jeff Bowlsby's classic 914 website, in the Plates, Labels & Numbers section. Just in case you're looking to verify all numbers on your 72. (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Lo-Fi Version | Time is now: 7th June 2024 - 01:04 AM |
