dudzy's914 |
The youngin' ![]() ![]() Group: Members Posts: 271 Joined: 21-December 13 From: Hatfield, MA Member No.: 16,784 Region Association: North East States ![]() |
Installing the engine/deck lid and having some confusion and the ol Haynes manual is no help. Looked through the forums but could find a good one... Maybe if someone could point me to a good one or answer these questions...
Question 1: does the deck lid tabs go on top of the mounts on the car? Question 2: how to thread the bolts in? Because the lid is set to be upright, thus leaving no room for the bolts... |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
Engine lid tab goes under body tab. Bolt comes in from underneath. Easier with another pair of hands.
EdwardBlume |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California ![]() ![]() |
Put it on loosely, then adjust. I just adjusted the latch L too, very easy. +1 on a lovely assistant for the install... enjoy!
euro911 |
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California ![]() ![]() |
Another tip: you can modify the hinge part on the engine lid, cutting the oblong holes into slots (with a dremel tool or equivalent cutting implement), so you can leave the bolts in place and slide the lid on, rather than having to position and hold it in place, then trying to start the bolts.
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,090 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
Yep.
TROJANMAN |
Looks nice in pictures......... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,271 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None ![]() |
Another tip: you can modify the hinge part on the engine lid, cutting the oblong holes into slots (with a dremel tool or equivalent cutting implement), so you can leave the bolts in place and slide the lid on, rather than having to position and hold it in place, then trying to start the bolts. Does anyone have a pic of this? I need to install my engine lid before trailing the car home. I'll have a second set of hands, but if this makes it easier......... I've done the search, but came up with 40 pages of results. Thanks (IMG:style_emoticons/default/smile.gif) |
barefoot |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,281 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States ![]() ![]() |
It helps to have someone stand on the seats & hold the lid while you attach bolts from under. (IMG:style_emoticons/default/slap.gif)
Lo-Fi Version | Time is now: 8th June 2024 - 03:35 AM |
